Educator MXP Maintenance
I believe I’ve come across one of the big problems with this maint.
--Only the CTS-EDU-INTP-K9 has been extended to last hardware support date of Jan 31, 2015 (see EOL 7908)
*This is the Educator MXP IntPack, NPP - With 1 Precision HD Camera
THIS IS CISCO PID#B5009223N (TANDBERG Service P/N #B5009223NV27)
Which we would look to be quoted: Partner Core-Bridge NBD Master Level ATP Service P/N #CON-PMDN-EDUINTP
We keep getting quotes reflecting Prec. HD cameras, even though we have WAVE II cameras.
THE PROBLEM:
My org currently has:
CISCO PROD ID #CTS-EDU-B500922N
PROD DESCRIP: Educator MXP IntPack, NPP With Wave II Camera
TANDBERG Service P/N # B500922NV27 (B500922N – Wave II Camera Educator Integrator Pack)
(This is effectively the same as CTS-EDU-INTP-K9, however it uses the Wave II cameras)
Partner Core-Bridge NBD Master Level ATP #CON-PMDN-CEB5922N
  • CISCO PROD ID #CTS-EDU-B500922N HAS/HAD A LAST DAY OF HARDWARE SUPPORT AS 1/1/12
The issue comes down to this:
Will Cisco force Me to purchase maintenance on the supported product PLUS purchase separate maintenance the WAVE II cameras?
CISCO PROD ID #CTS-WAVEII-NTSC=
PROD DESCRIP TANDBERG WAVE II Camera
TANDBERG PID #112500N
TANDBERG SERVICE P/N #112500NV27
Partner Core-Bridge NBD Master Level ATP #CON-PMDN-CWAVNTSC
LAST DAY OF HARDWARE SUPPORT 1/31/15
--I would then be essentially paying for maintenance on hardware it doesn’t have (the HD cams) just to get maintenance on the hardware it does have –the panel, controller and codec.
I’m not sure if I’m missing something or if Cisco is missing something..but I think we’d like to have a Cisco product specialist or maintenance specialist to address this
1 ACCEPTED SOLUTION
Hey Mark,
Please check your PM.
- Paula
No one can forward this to a product or maintenance specialist they know that covers the U.S., Great Lakes/Midwest region?
Hello Mark,
My apologies for the delay in responding to you as this is the technical support forum monitored by engineers who are not involved in the maintenance pricing/coverage.  I recommend that you reach out to your sales rep/account manager to clarify this.
Paula Talamo
That's why I've resorted to posting here...I raised the issue with rep/account manager May 4th..No repsonse to issue..other than "we're working on it"
Hey Mark,
- Paula
Re: Educator MXP Maintenance
Checked, replied. Thank you very much Paula
624
