10-17-2013 06:03 AM - edited 03-18-2019 01:59 AM
Dear All,
I have Demo contains of :
Site 1 : { CUCM + IP communicator + Xlite app " like ip communicator but can make video call " + switches and router } with supnet 192.168.1.0 /24
Site 2 : { EX60 unit +IP Phone + IP communicator + switches + router } with supnet 172.16.3.0 /24
I add the Ex60 as a third party sip endpoint and it successfuly registered to CUCM and i can ping it from site 1 perfectly .
also i can make a Voice call without any issue , BUT when i make a VIDEO call from site to another the call droped after less than 1 Sec and the EX60 goes unregestered for while then registered again .
when i made the VIDEO call from Xlite to Ex60 the issue happened .
when i made only a VOICE call from IP communicator OR Xlite to EX60 the call went perfectly with no issues .
The VIDEO and VOICE call working very well inside the lan { at the same site } .
The problem here Why the Video call dropped from site 1 to site 2 and why the video units went unregistered ?
ThANKS AND BEST REGARDS
MOHAMED MOKMHTAR
VOICE SYSTEM ENGINEER .
Solved! Go to Solution.
10-18-2013 03:27 PM
Hi friend,
What version of CUCM are you using? Why are you registering EX60 to CUCM as third party device?
Well, it is important to point that, in order to have TC endpoints (EX, C, MX and SX series) working without limitation with CUCM, you must to have CUCM 8.6.2 or later, and your endpoints should have the version TC5 or later.
This method you are using is too old and there many limitations. I strongly recommend you to use the recommended versions. Take a look at these guides with title "Administering TC endpoint on CUCM":
http://www.cisco.com/en/US/partner/products/ps11327/prod_maintenance_guides_list.html
I hope this help.
Paulo Souza
Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
10-18-2013 06:01 PM
What version of EX60 are you ruuning?
Well, anyway, you should have version TC 5 or later if you want to register it to CUCM 8.6.2. This method you are using is only applied to old versions of CUCM. Just follow the guides I linked above, that will help you.
Paulo Souza
10-18-2013 03:27 PM
Hi friend,
I hope this help.
Paulo Souza
10-18-2013 04:20 PM
thank you for your help ,
the CUCM version is 8.6.2 and i registered EX60 as third party because i tried to add it normally like normal cisco phone with standard sip profile but that didn't help because it has an old version .
does the video call down because there are limitations ?
10-18-2013 06:01 PM
Paulo Souza
