Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
EX90 and Telepresence ISDN link Outgoing call fail
Hi all,
I have a EX90 connected by network to the Cisco telepresence isdn link.
I connected the Isdn link to the Pri , and i have the status OK.  i can receive the incoming call, but i cannot make an outgoing call to the isdn.
I dont know how to troublshoot this issue , and also i woul ask if tehre is a possiblity to test an outgoing call directlty from the isdn link?
The Isdn link is paired with the EX90.
Thanks in advance
regards
Cham
If you are getting incoming call this means ISDN pri is working and configured .
What is software version running on codec and link ?
If it is 5.x and IL 1.0 then you need to use dial pattern :
isdnlink@cisco.com;x-h320number=xxxx.
If it is TC 6.x and IL 1.1 then use
For TC 6 you don't have to dial complex string when dial using remote / web , just enter number and select protocol H320.
hth
Kind regards,
Dharmmesh
Hi Dharmmesh,
I am experiencing the same problem with my SX20 connected to ISDN link. SX20 is TC6.3 and ISDN is IL1.1
I can receive incoming calls but cannot dial out, it says call has disconnected.
Hopefully you can help me as I am figuring this out for 3 days already.
Thank you in advance.
Albert
VIP Purple
I think Dharmmesh may have had a copy and paste issue.
For TC6.3 (or TC7.x) and ISDN Link IL1.1, Dharmmesh's last sentence is the correct one, not the example above it.  You just need to dial the number and have the protocol set to H320.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
892
