EX90 Touchpanel not allowing Multisite
I have an EX90 with  a multisite license. I am running TC4.2.4. The option to add participants is not showing on the panel at all. Any suggestions?
Thanks!
Chris
1 ACCEPTED SOLUTION
Re: EX90 Touchpanel not allowing Multisite
First of all I would recommend to upgrade the software of you endpoint.
TC7.0.2 is the latest.
http://software.cisco.com/download/release.html?mdfid=283645026&softwareid=280886992&release=7.0.2&relind=AVAILABLE&rellifecycle=&reltype=latest
TC4.2 is some time ago and the control via the touch screen evolved till then, so this could be the reason.
Besides that, at least current systems have the option to switch in between multiway and multisite,
if multiway is enabled miltisite is disabled. Check on the system config.
If getting lost, sometimes a factory default reset can also be helpful (but that also requires you know the basic settings)
Please also double check that the license key is really present.
Please remember to rate helpful responses and identify helpful or correct answers.
Are you not able to dial while in a call? I don´t remember hos this looks like on TC4.2 but there should be an option to dial? Dialing a second participant while in a call would setup a multisite call.
/Magnus
There is no option on the touch panel to add participant.I have 2 other units where the option shows up running different flavors of TC4.x
I factory rest the unit and it is working now. Thanks for the help guys
thx for setting it to answered and giving the feedback on how you solved it +5 for that!
Anyhow, please consider upgrading the systems, for security and usability,
the touch interface really improved!
VIP Green
Hi Chris,
As Martin has indicated in his post above, it is highly recommended that you upgrade your devices from TC4.x to something more recent.
There are a number of security vulnerabilities in software pre TC6.1 - see
http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20130619-tpc for details.
If you have an active service contract on your devices, I recommend you upgrade to one of the latest releases (ie TC7.0.1), If you don't have an active service contract, you will be able to get a "free" upgrade to TC6.1 by contacting the TAC and requesting the upgrade as per the details in that security advisory.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
195
