EX90 Touchscreen Cable Length
We have the standard touchscreen CTS-CTRL-DV8=  with our Cisco EX90's.  We have a few instances where we actually need a longer cable between the touchscreen and the EX90.  Are there any available, or any other options to extend this?
1 ACCEPTED SOLUTION
Silver
you may find  few threads already closed on this, yes you have the option to increase the length however
the Handset will not work : limitation
two option : a c series toouch panel which is longer than ex90 touch
or install a POE adapter PSU-DVC-POE13V= and connect the same EX90 touch on the network (pair) .
same can be done for the C series touchCTS-CTRL-DVC8=
refer to the threads below:
https://supportforums.cisco.com/thread/2179316
https://supportforums.cisco.com/thread/2098588
Ravi Kr.
1 REPLY
Silver
Ravi Kr.
1549
