Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
EX90 Wall Mount
can´t find any info, if EX90 is wallmountable. If yes, which VESA dimensions are suitable?
thx!
Tino
1 ACCEPTED SOLUTION
EX90 Wall Mount
Tino,
The EX90 is not wall mountable.  It has no VESA holes on the back of it.  The only way to wall mount it would be to create a custom mount of some sort.
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
EX90 Wall Mount
Tino,
Justin
Thank you,
Justin Ferello
EX90 Wall Mount
thanks, Justin
1188
