Expressway Core XCP Server connection question,and C and E connect ok,but jabber can not access from core
dns-inside:cucm/cups/expressway-c/expressway-e /AD  and all srv
dns-outside:expressway-e and all srv
cucm/cups/expressway-c/expressway-e /AD/dns-inside/dns-outside all in one network
dns-outside we use inside test,later we will put in outside .
now /expressway-c/expressway-e  connextion ok.
inside jabber can user user@domain.com login in ,Don't need to fill out any IM address(sso login)
at dns-outside server we use user@domain.com,can not login,when we use IM address:expe.domain.com also can not login.
expressway-e:status>>unified communication   all is active
expressway-C:status>>unified communication   all is active except
XCP Server connection: 192.168.99.13  (expressway-E)
Inactive Jabber is not running on remote host, if jabber is running then check password for r2r connection on connect
jabber can not login in on  dns-outside ,help ?
I can login but externally, I get an error that “no communication with server”. When I deliberately put a wrong password, I get an error message that with wrong username and password. The Services Discovery is also working because I’m getting the correct IM server information.
task1: expressway core have one not active
XCP Server connection: 192.168.99.13(edge) :Inactive Jabber is not running on remote host, if jabber is running then check password for r2r connection on connect
task2:on cupm server have two servervice not running ok
Cisco XCP Message Archiver and Cisco XCP Directory Service status Not Running ,activation status   Activated
taks 3:about ip or FQDN
on my cucm system>server ,i use IP not for FQDN
on my cups application>Legacy Client Settings,i use IP not for FQDN
is this question?  if i must change server list from ip to FQDN ?
What is the need to pay attention to ?
taks4:in my network
i direct connect core and expressway use LAN1.
inside-jabber pc and outside-jabber pc use diffrent DNS
inside and outside dns or srv is ok.
in my test,inside-jabber pc  can login ok,
outside-jabber pc  can not login
if test ok,we will put out-side dns server in internet ,and nat expressway-edge (which port?)
or use lan2 connection  internet (if we will add some route for lan1 and lan2 ?)
i s can ok?
thank you for your help.
note 1 :
if i shut expressway-E LAN2 , This log is ok---XCP Server connection: 192.168.99.13(edge) :Inactive Jabber is not running on remote host, if jabber is running then check password for r2r connection on connect
all is active.
but i can not login in from outside ?
note 2 updata 2014-09--04 21:28:
now ,on expressway-E i use IPv4 static NAT mode .my expressway core and edge is ok
my nat and dns is ok. i can login in jabber from outside any where.or inside any where.
i can login from outside ,but i can not use softphone ?
Everyone's tags (1)
477
