Expressway-E SSL Cert Trial Work?
I just deployed the VCS 8.1 ova for the Expressway-C and Expressway-E about the demo of VPN-less Jabber. It is successful for me to configure the Expressway-C and the Expressway-E, but I cannot make the commnication between the "Traversal Server" (E) and the "Traversal Client" (C) with the Mobile Remote Access through the TLS, because it need the cert. as the validation. I want to use the the trial public CA to generate the certs, but I suffered on the cert. error; "The file provided does not have a server usage attribute".
PS: I am using the symantec trial cert. (https://trustcenter.websecurity.symantec.com/process/retail/trial_product_selector?uid=abf536a4864459d743f0fe26063fcac9&locale=VRSN_US&language=en)
Actually, it is successful to upload the Root CA provided by the symantec, but it is fail to upload the server cert.
How can I solve it out?
1 ACCEPTED SOLUTION
Re: Expressway-E SSL Cert Trial Work?
Sign your own certificate using OpenSSL
If you want to use OpenSSL to create your own CA cert and sign your CSR, it is actually easier than you’d think.
Start at the bottom of p.12 of this document –
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/X8-1/Cisco-VCS-Certificate-Creation-and-Use-Deployment-Guide-X8-1.pdf
you can generate the CSR "certificate signing request" from the VCS and copy this file to your PC where you are running openssl.
You’ll need to follow the procedure twice.  Once for Expressway-E and once  for Expressway-C.  Take the CA root cert that you generated and import  it into the trusted list on both boxes, and then import your signed  server cert on the appropriate box.
regards
Alok
to setup the TLS connection between Expressway-E and Expressway-C, its important that the certificate installed on the traversal server and traversal client should have two attributes i.e. client and server, and then only TLS will work.
you can use openssl to generate the certificates.
Alok
Thanks for your reply!
You mean I can generate the self-signed from the openssl? Would u mind how can I do it from the Expressway-E? Really Thanks!
regards
Alok
I can generate the certs. into the Expressway-C and th Expressway-E, but it still fail to trunk the zone from the "Traversal Server" (E) and the "Traversal Client" (C) with the Mobile Remote Access through the TLS.
Any idea? Atcually, I don't know wht can I import about the "TLS verify subject name"? That should be the Expressway-C Cert. "Subject Common Name"?
Expressway-C error: SIP: Failed to connect to :7001 : TLS negotiation failure
Expressway-E
StateFailed
yes, that's right. the CN in the certificate is what you define on the expressway-E.
can you tell me on the expressway-c under the traversal zone it is pointing to ip-address of expressway-e or its fqdn ? it should be fqdn of expressway-e defined under its certificate.
also what attributes are assigned to your certificate on expressway -E & C ??
regards
Alok
Thanks for yr Hits! After I changed the FQDN as the Subject CN of the certs., then the TLS can be formed.
Now, the "Traversal Zone", UC to CUCM and Presence server are working right now.
Actually, the Jabber still cannot reg. without the VPN. I still have some confused matters as below:
1. How to identify the internal and the external domains
My Expressway-C, CUCM, Presence server domain is: company.local
My Expressway-E with dual networks domain is: company.com
As the outside Jabber, then I should type the @company.local OR @company.com? Where's the translations? The outside Jabber will lookup the internal DNS SRV records 1st, then lookup the external DNS SRV record? jabber-config.xml to control that? (XML: ON)
Actually: I just want to the jabber reg. to the CUCM, because that is the free.
 Hi Edwin!I've been
Hi Edwin!
I've been experiencing the same issue, could you tell me how you resolve that issue?
VIP Super Bronze
For cucm and IMP server  and
For cucm and IMP server  and expressway certs you need to do the following:
Generate CSR (tomcat)>generate CSR>send to CA to sign on all IMP and CUCM servers
Upload CA root cert as tomcat-trust
Upload signed cucm and IMP certs on all servers
Upload root CA cert to expressway e and c
Generate CSR for expwe and c, send to CA to sign and use web and client server template
Upload cert as server certs.
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
2406
