Firewall Port Check Utility for VCSe
Hi Experts,
Is there any way , we can check if all the required ports for VCSc and VCSe configuration are opened on firewall through some utility or some commands?
I am going to proceed fir VCSe config with VCSc and I want to make sure that all the required ports for H323/SIP/RTP etc are open , without relying on Customer's Network Admins
Any reply in this regard would be appreciable.
Saurabh
Vyopta has v2.2.1.34297 of the TANDBERG port tester available on their website;
http://www.vyopta.com/tools/IPT.exe
works with VCS-E
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Hi Saurabh,
i will send you one tool. Check you inbox.
Sagar
Hi Sagar  can you send it to me as well
Hemal
I think this utility is not been updated for quite sometime. Basically its easy if you see the firewall deplyoment guide to get the ports required and capture a tcp dump and you will get the idea on this..
below are the ports what you requite basically between internal to DMZ
SourceDestinationSource PortDestination PortDescription
TMS Server/mangment subnetVCS-ExpresswayAnyTCP-80/443Administration
TCP-22
UDP-161
VCS-control VCS-expressTCP-25000-29999TCP-7001SIP – Signalling
VCS-control VCS-expressUDP-50000-52399UDP-2776SIP – RTP/RTCP
UDP-2777
VCS-control VCS-expressUDP-1719UDP-6001H.323 – Initial RAS connection
VCS-control VCS-expressTCP-15000-19999TCP-2776H.323 – Q.931/H.225 Signalling
VCS-control VCS-expressTCP-15000-19999TCP-2776H.323 – H.245
VCS-control VCS-expressUDP-50000-52399UDP-2776H.323 – Assent RTP/RTCP
UDP-2777
Alok
Hi Hemal,
As Alok mentioned this utility may not be updated.
Please provide me your e-mail id so that i can forward it.
-Sagar
The port tester “IPT.exe” is developed for port testing to Boarder Controller product and haven’t updated for some time already.
Please note that this tool may use against VCS for testing H.323 connectivity but may not cover all requirements.
Cisco is currently plan for releasing update version of port tester in 2013 including SIP port testing capability.
The default Border Controller seems not to be working. Is this expected?
Kind regards
Maciek
Yes, that is expected result as original IPT program point to test BC server hosted by TANDBERG which has removed after Cisco acquisition.
Any idea when in 2013?  ty.
Due to other high priority implantation, very unfortunately port tester for VCS product yet made much progress.
2673
