Community Member
GUID value for TMS 14.4 to be configured on F5.
How to get GUID value for TMS 14.4 to be configured on F5.As per the TMS 14.4 upgrade guide, the GUID value of the TMS needs to be entered in send string for probing.
#CREATE MONITOR FOR TMS KEEPALIVE THE GUID IS FOUND IN TMS GUI tmsh create ltm monitor https mn-TMS-HTTPS {cipherlist DEFAULT:+SHA:+3DES:+kEDH compatibility enabled defaults-from https destination *:443 interval 5 password flott recv 200 recv-disable 503 send "HEAD /tms/public/IsAlive.aspx/?guid=<CHANGE TO THE GUID OF YOUR CISCO TMS>\\r\\n" time-until-up 0 timeout 16 username 'domain\\username'}
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Super Bronze
Are you referring to a
Are you referring to a redundant TMS deployment?
If so, take a look at page 31 under "Setting up the network load balancer" section.
You'll find the Probe URL in TMS with a GUID specific to that node here:
Administrative Tools > TMS Server Maintenance > TMS Redundancy > Probe URL
VIP Super Bronze
Community Member
Got it ! ;-) Thanks Patrick !
Got it ! ;-)
Thanks Patrick !
VIP Super Bronze
Glad you got it!If you would,
Glad you got it!
If you would, don't forget to make posts as correct or helpful for others that might later on have the same issues.
Community Member
Hi Patrick,I am in need of
Hi Patrick,
I am in need of your expertise yet again.
I successfully upgraded both of my TMS & TMSPe to 14.4 & 1.2 respectively, eventually i even managed to configure F5 as load balance for both of the sites and seems to be working fine
The only problem that i am getting is as follows
TMS web pages are garbled (icons missing, text misaligned etc) when i access using F5 virtual IP but the pages seems to be normal when i access it using directly URL of the TMS
Have you ever come across such issue (i already tried setting up page in compatibility mode, re installing the application etc)
Would appreciate your response / thoughts as always
VIP Super Bronze
What web browser(s) are you
I haven't set it our test TMS 14.4 server yet in a redundant deployment with a NLB, it sounds like an issue with the NLB.
Was this a previous redundant TMS deployment that you were upgrading or a new install?
Did you follow the install guide step by step?
Community Member
This was upgrade from 14.2
This was upgrade from 14.2 but there was no redundant setup before (as 14.4 has enhanced redundant feature on it )
I followed the installation / upgrade guide and infact did it twice
It seems something to be done on web server of TMS but not sure where to tweak the settings
VIP Super Bronze
I haven't upgraded our TMS
I haven't upgraded our TMS redundant deployment yet, I just have a single TMS server enabled as redundant for testing, though without a NLB in the mix yet.
It sounds like an issue with the TMS-NLB configuration, since you say that when you browse to the TMS servers directly, everything is displayed fine.  Just when you go through the NLBs, everything gets distorted.
Community Member
Old thread however we are
Old thread however we are going from 14.3 to 15.3. How do we get this ahead of time so we can raise a change request and provide the details to our Network colleagues that will be carrying out the F5 configuration?
VIP Super Bronze
If you're referring to the
If you're referring to the TMS ProbeURL, you won't be able to know what URL to configure on the F5 until you enable redundancy within TMS.
257
