Help Required (Codian ISDN 3240)
Hi guys,
I have a codian isdn gateway that I cannot log onto as admin because we have no Idea what the password is. Default credentials don't work and commands such as reset_config and reset_password-all when entered via console returns unknown command error. No idea what revision of software box is running.
Hi Irfan,
reset_password is the right command.
From the description, I see that you are using "reset_password-all".
Let me know if it works or not.
-Sagar
Hi Sagar,
Thanks for the repsonse.
reset_password via console returns unknown command error message.
any further further help would be appreciated.
regards
Hi Irfan,
type help on the prompt and it will display list of  commands.
Could you please paste the output?
-Sagar
Hi Sagar,
once agaian thanks for the quick response, below is the output via console when typing ? or help
? : Display commands
        help : Display commands
        dhcp : Use DHCP
      static : Use static IP
        ping : Test network connectivity
   ethertype : Set ethernet link type
      reboot : Reboot
    shutdown : Cleanly shutdown
      status : Show network status
destination : Manipulate IP destinations
     service : Control access to IP services
  ip_control : Control enablement of interfaces
feature_key : Submit a feature key
ISDN-GW:> help
        dhcp : Use DHCP
      reboot : Reboot
ISDN-GW:> Looking for host 10.2.10.4 and service ntp
Hi Irfan,
Its strange that I dont see reset-config option here. Give me a day and i shall be able to answer you.
As of now i don't have console access to my Lab gateway.
Also try this (not sure if this works)
-reboot the ISDN GW and execute reset_config within 30 secs once booting is completed.
-Sagar
Hi Irfan,
If you have forgotten your password for your Cisco acquired TANDBERG/Codian product you need to restore the unit to its factory settings to reset it. This will remove all configuration, including password
To return your unit to its factory settings and reset the password:
  1. Connect a serial terminal to your unit's console port using the settings given on the back panel label.
  2. Reboot the unit and watch the output on the serial terminal. After a few seconds you will see the message 'Cisco TelePresence MCU 8510 4.2(0.36) (Build 6.17(0.36)) starting' or similar.
  3. Type reset_config and press Enter.
  4. Type yes or y and press Enter. The unit will now reboot again.
  5. When bootup is complete, type status on the serial terminal to see the IP address that the unit has acquired using DHCP. Alternatively, set a static IP address on port A using the static command.
  6. Connect to the web interface of the unit and log in using 'admin' and no password. A warning message on the web page banner will tell you that a product activation key is required.
  7. Go to Settings > Upgrade and enter the unit's activation keys. After the activation keys are applied, you will be able to use your unit again.
To change the password, go to Users.
Alok
HI,
   Did you managed to get this one fixed ?
   If not please let me know and I can send you in a separate e-mail la webex invite and do it together once you have a pc with internet access and console cable conected to the unit
Kind regards,
Cristian
Hi Cris,
On my lab gateway, I am able to use commad reset_config. However When Irfan tries to use it, it returs with unknown command error.
Not sure if was different method on older firmawares
-Sagar
HI guys.  Have a 3220 GW on 2.1(1.49), and did the following:
Watched on the console for the following message:
"Hit Ctrl+C in the next 5 seconds to prevent isdn_gw start"
Once you see this, type in (no matter if it starts to scroll: Stare at the keyboard and type it): reset_config < hit enter> y
System will come around on boot, and then look to see in the console session for:
ISDN-GW:> reset_config
and....."Warning: This action is not reversible. Are you sure you want to continue?081317.561 SYSTEM : Info : Unique id "connection_id" was written; new allocation is 200000
y"
At least this is where it was written to mine.
Later on you may see:
081331.963 CONFIGURATION : Info : save operation 3656 (9203 bytes) took 25.679s
081331.964 CONFIGURATION : Info : Config file /fat/igw_cfg.bak preallocating
Waiting for configuration file to reset
Configuration reset"
Then it will go down for a restart.
Give this a shot and see if it works.  Once you see that first line, type that in and continue to do it no matter if it scrolls or not.
Let us know the outcome.  Thanks.
VR
Patrick
Many thanks for your help so far guys, but still no closer to logging on as admin. below is the output from the gw when performing the above steps recommended:
***** FILE SYSTEM WAS MODIFIED *****
hddstrap: product type 12
Hit Ctrl+C in the next 5 seconds to prevent ISDN GW start
^C# reset_config
rm: /fat/mcu_cfg.xml: No such file or directory
rm: /fat/mcu_cfg.bak: No such file or directory
Mar 29 15:11:01 reboot: rebooted by root
[1]   Terminated              reset_config
# syncing disks... done
rebooting
Hi Irfan - Run this again if possible, but don't hit ctrl-c to break the boot.  Once you see that line, just stare at the keyboard and type it in and let us know.
So, don't break the boot if you can.
Let us know.
VR
Patrick
Hi Patrick,
First, Thanks for the quick response, secondly i did as suggested and below is the output:
fsck: Cannot open `/etc/fstab': No such file or directory
** /dev/rwd0d
** File system is clean; not checking
reset_config
RUNNING ISDN GW
cfev: driver loaded successfully - built at Dec  7 2004 12:46:29
Module loaded as ID 0
/dev/rmd0c: 64.0MB (131072 sectors) block size 8192, fragment size 1024
        using 4 cylinder groups of 16.00MB, 2048 blks, 3968 inodes.
super-block backups (for fsck -b #) at:
    32, 32800, 65568, 98336,
net.inet.ip.ifq.maxlen: 50 -> 500
net.inet.udp.checksum: 1 -> 0
ftrace_init done
sendbatch_init
pci_init()
Hi Guys,
I could do with some further help, are there any other commands i can try whilst in ctrl and c mode.
Thanks guys
HI Irfan,
   It looks like we'll have to look into few logs to try to understand what's happening here so kindly asked to open a TAC case to further troubleshoot.
    Please attach to the case the serial output of the unit whilke trying to reset the unit password.
Its two major options.
There is something strange with your box
Guess thats covered with what Christian said.
There still might be a usability issue.
I dont know how I shall interpret your last output.
First you would have to boot up the MCU (which this is parts of the output) you do not need to
press ctrl-c or anything like that. In the first 30 sec after the system is rebooted and up and running
type in: reset_password
Did you do that?
Agree,
I think we should look into the full serial log to have a better understanding of what's happening
Cristian
1224
