How to configure a firewall for a SX20 registered on a VCS Expressway
Hi all,
As you can see in the picture, I have a classic situation. Everything is working properly.
Now customer needs to use a cisco SX20 in a branch office.
The Cisco ASA 5540 firewall is currently configured as follows:
  1. static (inside, outside) 213.42.140.136 (public ip) 10209252166 (internal ip)
  2. access-list extended permit ip host 87.241.12.76 OUTSIDE_access_in (VCS Expressway IP) host 213.42.140.136
I have done many tests:
  • SX20 H.323 configuration whit Nat On, Off and Auto
In all cases the system is recorded correctly, but the call signaling does not occur.
  • If instead of using my own system with a public IP it works fine.
Can anyone help me how to properly configure the firewall?
thanks in advance
  • TelePresence
1 ACCEPTED SOLUTION
Check on the asa that threre is no fixup / inspection enabeld for sip, h323 and skinny.
You find a doc regards voip and ASA here:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008081042c.shtml
Re: How to configure a firewall for a SX20 registered on a VCS E
What does the ASDM on the firewall say in terms of logging of blocked traffic when it doesn't work?
The firewall manager, says that there are no packets dropped.
thanks for the quick response
What log level are you looking at?
Does it show the packets getting through?
Thanks Martin
Following the guide  that you suggested I configured the firewall and now everything is working properly.
Best Regards
1446
