Community Member
How to determine traversal calls?
Hi all,
As we can see at the site below,
"a SIP to SIP call when one of the participants is behind a NAT (unless both endpoints are using ICE for NAT traversal)"
is handled as  a traversal call by VCS.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/articles/vcs_traversal_call_license_usage_kb_168.shtml
But how does the VCS know that one of the participants is behind a NAT?
Does VCS check if there is a difference between a value of "Via" header in SIP header and "C" type in SIP body?
Best Regards,
Kotaro Hashimoto
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: How to determine traversal calls?
If SIP UA’s sip contact address differs from source IP address, then VCS will determine this SIP UA is behind a NAT and treat as firewall traversal client/call.
This is a reason call will treat as non-traversal call on some of Jabber Video (Movi) public deployment with mobile connection (i.e. 3G mobile card) where IPS assign public IP address on client PC directly.
500
