03-18-2014 04:52 AM - edited 03-18-2019 02:44 AM
Hello dears,
I have TCS server version 6.0 on windows 2008 server and i need to performing software reimage and i download license file from cisco.com/go/license then i entered H/W serial to download the detailed information related to License data file but i can't found checksum to fill it in field.
So how to get checksum to import it in license data file
03-18-2014 11:18 AM
If the TCS 6.0 licensing mechanism is same as 5.0, you should find the checksum in the windows' registry table. You need to backup first, then edit the value.
07-21-2014 12:36 AM
Hi did solve this problem?
