Community Member
How to provision E20?
Hi. I have installed TMS on domain member server, we have VCS Control and VCS Expressway set up.
I managed to provision Movi client, using domain user credentials, but trying to use same procedure for E20 doesnt work.
If i add E20 as device in TMS->Systems->Navigator, i have to specify VCS's localy added account. Using domain user account doesn't work (causes authentication error).
So, what is correct way to provision E20 devices?
Everyone's tags (4)
Re: How to provision E20?
Did you setup yhe provisioning extension or are Using the legacy tmsagent?
Did you upload the e20 configuration template?
/magnus
Community Member
I have installed extension right after installing TMS.
Yes, i did upload E20 template, version 4.1.1 as SW version of E20 itself.
Community Member
Thanks to support.
Problem was that i have used domain accout password and, since E20 does not support NTLM, i had to use password, supplied when i was creating user account on TMS.
There was also TLS issue after that, but that's another story. Just disabled TLS for now.
420
