Incoming and Outgoing Call Issue
I tried to deplu CUCM>VCS>VCS Express. but both incoming and outgoing calls are not working.
the following is search history for two calls one came from external endpoint to 1800@External_Domain.com (Error: Resource unavailable - No route for bandwidth calculation)
and another one from Cisco IP phone 1800@External_Domain.com (Error: Temporarily Not Available)
  Search (55)
        State: Completed
        Found: False
        Reason: Resource unavailable - No route for bandwidth calculation
        Type: H323 (Setup)
        CallSerial Number: fca3b1e8-e5a9-11e3-a963-0010f32f4ccc
        Tag: fca3b30a-e5a9-11e3-8335-0010f32f4ccc
        Source (1)
            Authenticated: False
            Zone (1)
                Type: Default
        Destination (1)
            Alias (1)
                Type: Url
                Origin: Unknown
                Value: h323:1800
        StartTime: 2014-05-27 17:20:00
        Duration: 0
        SubSearch (1)
            Type: Transforms
            Action: Transformed
            ResultAlias (1)
                Type: H323Id
                Origin: Unknown
                Value: 1800@External_Domain_com
            SubSearch (1)
                Type: Admin Policy
                Action: Proxy
                ResultAlias (1)
                    Type: H323Id
                    Origin: Unknown
                SubSearch (1)
                    Type: FindMe
                    Action: Proxy
                    ResultAlias (1)
                        Type: H323Id
                        Origin: Unknown
                    SubSearch (1)
                        Type: Search Rules
                        SearchRule (1)
                            Zone (1)
                                Type: TraversalServer
                                Protocol: H323
                                Found: False
                                Duration: 0
                                Gatekeeper (1)
                                    Address: 172.25.9.210:52242
                                    Alias (1)
                                        Type: H323Id
                                        Origin: Unknown
                        SearchRule (2)
                            Zone (1)
                                Protocol: H323
                                Found: False
                                Duration: 0
                                Gatekeeper (1)
                                    Alias (1)
                                        Type: H323Id
                                        Origin: Unknown
    Search (51)
        State: Completed
        Found: False
        Reason: Temporarily Not Available
        Info: Bandwidth allocation failed
        Type: SIP (INVITE)
        CallSerial Number: c9f4f8a6-e5a9-11e3-9cdb-0010f32f4ccc
        Tag: fd686a1a-e5a9-11e3-9452-0010f32f4b8c
        Source (1)
            Aliases (1)
                Alias (1)
                    Type: Url
                    Origin: Unknown
            Zone (1)
            Path (1)
                Hop (1)
                    Address: VCS-Control IP:5060
                Hop (2)
                    Address: CUCM IP:5060
        Destination (1)
            Alias (1)
                Type: Url
                Origin: Unknown
                Value: sip:61062032@Exteranl_IP_address
        StartTime: 2014-05-27 17:18:35
        Duration: 0.02
        SubSearch (1)
            Type: Transforms
            Action: Not Transformed
            ResultAlias (1)
                Type: Url
                Origin: Unknown
                Value: 61062032@Exteranl_IP_address
            SubSearch (1)
                Type: Admin Policy
                Action: Proxy
                ResultAlias (1)
                    Type: Url
                    Origin: Unknown
                SubSearch (1)
                    Type: FindMe
                    Action: Proxy
                    ResultAlias (1)
                        Type: Url
                        Origin: Unknown
                    SubSearch (1)
                        Type: Search Rules
                        CallsToUnknownIPAddresses (3)
                            Mode: Direct
                            Zone (1)
                                Type: Default
                                Protocol: SIP
                                Found: False
                                Duration: 0.01
                                Gatekeeper (1)
                                    Alias (1)
                                        Type: Url
                                        Origin: Unknown
Could you please help:
It looks like the neighbor
It looks like the neighbor zones to CUCM doesnt exist. Have you followed the guide:  http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Cisco_Unified_Communications_Manager_Deployment_Guide_CUCM_8_9_and_X7-2.pdf?
Please rate useful posts.
it is existbecause I am
it is exist
because I am making calls from CUCM to VCS and calls reach to VCS express. I have used the guide.
Could you share a screenshot
Could you share a screenshot from the search rules page? If you are using transforms for manipulating called number, please provide that as well.
I do not have access right
I do not have access right now, but I can tell you the configuration
For calls coming from outside to CUCM. I am dialing like this:
1800@Real IP address
when I checked the incoming calls I found the address only 1800, so I created a transform to to transfer from 18(..) to 18\1@domain.com
then a search rule .*@domain.com to (traversal zone > VCS Control) the same search rule it is created in VCS control > neighbor zone (CUCM)
What version of UCM are you
What version of UCM are you using? Have you set the Clusterwide FQDN to the domain that you specify in VCS? If not the calls wont work.
Also, i dont think the call is hitting a CUCM neighbor zone from the debug you posted initially.
Its going to VCS Express after it matches the last rule which I think in your case is to route to VCS Expressway.
I have CUCM 10FQDN is
I have CUCM 10
FQDN is configured in CUCM.
The first debug is related to call coming from outside to CUCM, I take the output from VCS-Express. It is showing that call is forwarded to VCS Control
  SearchRule (2)
                            Zone (1)
                                Protocol: H323
                                Found: False
                                Duration: 0
                                Gatekeeper (1)
                                    Address: 172.21.8.143:52242
                                    Alias (1)
                                        Type: H323Id
                                        Origin: Unknown
it looks from the information
it looks from the information that you may need to relook at your transforms and search rules
Could you please give me more
Could you please give me more details,
Did you read the configuration that I added in the previous post:
any thing wrong here?
I meant to add a little more
I meant to add a little more to the post. What would be needed is to see all the search rules their order/priority, transforms, pipes/links and zones in order to determine where the issue is. Maybe even the dial plan also. If all that is correct then we'll look at the CUCM, but it doesnt look like the call is making it that far along.
Hi,I have the following
I have the following configuration
VCS: SIP domain: abc.com
Transorm
PriorityDescriptionPattern TypePattern stringPattern behaviorReplace string
10to accept call from CUCM E164** IP address to E164@real IP addressRegex(.*)\*\*(.*)\*(.*)\*(.*)\*(.*)(@.*)Replace\1@\2.\3.\4.\5
15to transfer from IP address**E164 to E164@IP addressRegex(.*)\*(.*)\*(.*)\*(.*)\*\*(.*)(@.*)Replace\5@\1.\2.\3.\4
20Direct IP address Regex(.*)\*(.*)\*(.*)\*(.*)(@.*)Replace\1.\2.\3.\4
Zone#TypeH.323 statusSIP Statussearch rules
CUCMneighbourOffActive1
VCS-ExpressTraversal ClientActiveActive1
Rule NameDescriptionPriorityProtocolSourceAuthenticatedModePattern TypePattern stringPattern behaviorReplace stringSucessful matchTarget
SR_CUCMTo send calls to CUCM80AnyAnyNoAlias Pattern MatchRegex(.*)@abc.comleave stopCUCM-zone
External IP 90AnyAnyNoAny IP address    ContinueVCS-Express
Dial Plan Configuration
 Calls to unknown IP address Indirect
on VCS Express
same SIP domain
Transorm
5To call by ExtensionRegex19(..)Replace19\1@domain.com
Zone
DNSDNSONON1
VCS-ControlTraversal ServerActiveActive2
Search Rule
IP_Phones 70AnyAnyNoAlias Pattern MatchRegex(.*)@abc.comleave ContinueVCS-Control
DNS_SR 150AnyAll zonesNoAlias Pattern MatchRegex   ContinueVCS-Express
Hi,I was thinking about this
I was thinking about this portion:
Gatekeeper (1)
                                    Alias (1)
                                        Type: H323Id
                                        Origin: Unknown
The previous IP Address (gatekeeper) is my VCS-C but the phones are registered to CUCM and no phones are registered on VCS-C
What format are you dialing
What format are you dialing from VCS to reach CUCM? The call flow should be VCS <>CUCM. Calls will only traverse through VCS Express when it needs to go out of your organization. So for a call coming in from the internet, the call flow will be VCS Express <> VCS <> CUCM.
What exactly are you dialing to get to CUCM? Are you dialing extn@CUCMDomain or extn@CUCMIP? I would focus on getting calling between VCS and CUCM working before throwing VCS Express into the mix.
I am dialing from internet
I am dialing from internet (another system) Exten@Real IP address
Real IP address>>VCS Express.
from VCS Express to VCS (traversal)
from VCS to CUCM (neighbor zone)
Do you have any endpoint
Do you have any endpoint registered on VCS that you could test with? If you have a video endpoint, i would temporarily move it to the VCS for testing calling between VCS <>CUCM.
I used x-lite software it
I used x-lite software it registers with VCS and I make a call from VCS to CUCM and from CUCM to VCS. it should be OK. I faced some problems in this software so that I have created another discussion to see if someone can recommend another software.
Ok, what do you have for
Ok, what do you have for search rules of the VCSE? What are you dialing from the outside to get to CUCM?
Form Outside I'm dialing 1800
Form Outside I'm dialing 1800@MyRealIP_Address.
I am making the call from H.323 Endpoint. when I checked call history I found the incoming call number is 1800 only so I have created a transform to change 1800 to 1800@domain.com
Transform:
18(..)  Replace by 18\1@domin.com
then a search rule with (.*)@domain.com leave and forward it to traversal zone. (VCS)
by the way the URI directory on CUCM is 1800@doamin.com
I was thinking about your
I was thinking about your post (+5) (It looks like the neighbor zones to CUCM doesnt exist) it could be firewall issue between VCS-Express and CUCM. In the other hand if it is firewall why I can reach VCS-Express from CUCM (by making call from CUCM to VCS-Express)?
VCS Express ideally shouldnt
VCS Express ideally shouldnt integrate with CUCM, only VCS Control should. Have you created search rules/zones on VCS Express to route to CUCM?
374
