incoming and outgoing calls from/to VCS Expressway
Hi everyone,
I have one customer he has Polycom video conference solution. now they are going to implement Cisco Tandberg, I want to configure the new solution to simulate the old one. I have now two points are not clear for me and hope someone can help:
1- Dialing outside (out of the organization):
They are dialing some addresses like this: 12345@80.138.20.54, extension or E164 followed by the Real IP address.
2- Receiving Calls:
If someone out the organization wants to call someone inside, he can call like this 80.80.90.45##1199 (Real IP address ## Extension)
anyone can give me hints about how I can do this in VCS Expressway
1 ACCEPTED SOLUTION
VIP Purple
You replied before I could
You replied before I could edit my post.  In the past when I had a Polycom soft client on my computer, I was able to dial into our video network via a VCS with the Polycom formatted address (IP##alias) without issue and without any configuration on the VCS.
The transform would only be needed if you were inside the network calling out with a Polycom client and used that type of address to call out.
VIP Purple
This will still work with
  1. This will still work with Cisco products.
  2. You can use the following transform to convert Polycom formatted addresses to Cisco.
    • Type:  Regex
    • Pattern string:  (.+)##(.+)
    • Pattern behavior:  Replace
    • Replace string:  \2@\1
Thank you for your reply, Do
Do you mean I have to create transform?
VIP Purple
thank you fro your reply,in
in the previous cases shall I take care about the protocol or no need the VCS will take care and while I have traversal license
VIP Purple
I meant to say, depending on
I meant to say, depending on the Polycom endpoint and software version, it should be able to call either H323 and/or SIP, to limit interworking.  I can't say which Polycom versions etc, as I only support 1 Polycom HDX codec in our huge pool of Cisco codecs.
Thank you too much, the
Thank you too much,
the scenario that I have is CUCM => VCS Control => VCS Express to replace Polycom.
so VCS express should accept the incoming calls using this template:
Real IP address ## Extension , as per my understanding I have to do the following (please correct me if I am wrong)
VCS Express: Transform (Real IP address ## Extenstion) to extension@domain.com through the traversal zone
VIP Purple
Correct, the transform needs
Correct, the transform needs to be on the VCS where you might call using that scenario.
434
