Integrating CTS3210 and CTS1300 with RadVision
How I can integrate CTS3210 and CTS1300 with RadVision ?
1) I can integrate them only CUCM with GK RadVision by H.323 trunk to CTS3210 and CTS1300 communicate with RadVision endpoints end-to-end by RTP?
OR
2) I can integrate CUCM - VCS with GK RadVision by H.323 trunk to CTS3210 and CTS1300 communicate with RadVision endpoints by RTP through TelePresence Server 8710 ?
Best Regards
Marques
it depends on the cucm and cts versions
if you use cucm version 8.6 and later and cts 1.7.4 and later you can have direct call to via CUCM
however there will be no video transcoding
if any video transcoding required then you will need the TP server or MXE in the RTP path
for more details see this ask the expert session Q&A might help you
https://supportforums.cisco.com/thread/2123753
hope this help
if helpful Rate
Hello marwanshawi,
In both scenarios below can you inform the links for configure ?
1) if you use cucm version 8.6 and later and cts 1.7.4 and later you can have direct call to via CUCM
2) if any video transcoding required then you will need the TP server or MXE in the RTP path
Best Regards.
631
