Is a VCSE required for internet calls
Hi All,
I have a BE6K solution with a VCS-C VM installed but unfortunately I cannot install a VCS-E as the server is only medium density and only supports 4 application VMs.
I have registered two SX20s to the VCS-C using h323/SIP and configured the VCS-C with zones and search rules to allow external internet calls. Out of curiosity I also configured a direct NAT to the VCSC from a public IP address and inbound h323/SIP calls work without any issues.
Is this acceptable for a small scale solution and not use a VCSE? My only other choice is to remove the VCSC all together and just have standalone SX20s.
Many thanks,
Everyone's tags (1)
VIP Super Bronze
For security purposes, you
For security purposes, you definitely need a vcse. Your VCSE would sit in your DMZ and your VCSC will sit in your internal network. All traffic to and from the internet should be sent via your VCSE. Your VCSC shouldn't be connecting to the internet at all..Thats a big risk you are taking even for a small deployment
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Thanks for the reply. This is
This is just testing at the moment as I was curious on the how the technology was working.
Are there any major security risks with configuring NAT to a standalone SX20?
Hi,Ideal solution for your
Ideal solution for your requirement would have been a VCS-Expressway starterpack. However, I dont think that is possible to deploy on a virtual environment.
You can however, buy a VCS-Expressway now to make it work.
81
