Community Member
Is WebEx Enabled TelePresence supported with Expressway Core and Edge?
Is WebEx Enabled TelePresence supported with the Expressway Core and Edge instead of using a VCS Control and Expressway? This is one thing I'm not sure of, as the scheduled conferences will have to register to the Expressway Core and wasn't sure if this was possible.
1 REPLY
Hi,It is supported, see the
It is supported, see the following release notes here:
http://www.cisco.com/c/en/us/td/docs/telepresence/infrastructure/tms/release_note/cmr_hybrid_RNs_14_4.html#pgfId-164481
Expressway-E/C use is also covered in the deployment guide:
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tms/config_guide/cmr_hybrid_config_guide_tms_14_4.pdf
-Jonathan
Edit - links
166
