ISDN GATEWAY and PRI
Shy Solenko
Hello
I have PR that include 30 phone lines, and  i'm using with fax and telephone with 10 from it.
can i use the remain free lines with the isdn gateway... or do i need new pri line?
I'm will gld to some help with this issue
thanks
Martin Koch
The question would be how you plan to distribute the calls.
If you have a device like a pbx which can do so which does not tamper with the signaling / call it should work.
Also check that the line itself suports video conferencing.
The easiest might be to just get a new line.
Please remember to rate helpful responses and identify helpful or correct answers.
Martin Koch
