Issue paring C20 with ISDN Link
Hi, Can anyone can help me on initial connectivity of C20 with ISDN Link? I have C20 codec with 1 LAN port which is connected to endpoint port of ISDN Link, the LAN port of ISDN Link is connected on internal LAN. I have configured the ISDN Link IP :XXX.XXX.XXX.251 and codec on XXX.252 both are same subnet.
Since there is single LAN port, How I can access the web interface of the codec to check and perform the pairing? If in case the codec is on older firmware not supporting auto pairing then how I can perform the manual pairing. Can only access the ISDN link through serial.
1 ACCEPTED SOLUTION
Can´t you just plug your PC into the internal LAN (same subnet as the ISDN Link and the codec) and access the webinterface of the codec: http://x.x.x.252 ?
What software versions are you running?
/Magnus
/Magnus
I connected the PC on Video VLAN on which the ISDN Link and Codec is but not able to get the web interface of the endpoint. I am only getting the ping response from the ISDN Link. The codec is running on lower version than 6.x.
516
