Jabber can't 'work' from external (internet) but 'work' fine from internal.
Hi All,
I had issues with my jabber,
in my case I just use local DNS server for internal jabber client and use etc host for external jabber client in laptop.
Login and call from internal jabber works fine, but I can't login use jabber from external ( internet).
There is no firewall in my LAB topology,
just :
                                             -> MCU 5310
public -> router -> switch     -> VCS-E (static NAT 1:1)
                                             -> VCS-C
                                             -> TMS
VCS-E use single NIC and it NATed 1:1 to public.
and here is screen capture DNS lookup from my VCS-E and VCS-C.
Please advise..
thanks
Ovindo
1 ACCEPTED SOLUTION
Hello!
In short, if you use 1:1 NAT it is mandatory to have the "dual interface option", even if you only
use one interface, but that enables a field to define the external nat-ip address.
Also all communication to that interface have to go to the external ip address.
You want to use SRV records in addition to the a records if that domain shall be reachable.
Check out the deployment guides, especially:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Basic_Configuration_Control_with_Expressway_Deployment_Guide_X7-2.pdf
Besides that, there are many postings addressing similar issues here in the forum, please use the search and/or google.
Please remember to rate helpful responses and identify helpful or correct answers.
Hello!
Dear Martin Koch,
Ovindo
411
