Jabber ipad for Telepresence Far End Camera Control for MCU Auto Attedant
Hi All,
it is possible to set over the ipad, if we join to the Auto Attendant on the MCU to serverval conference rooms. How i can move  the arrow on the Auto Attendant on the with the iPad?
is that possible?
THX
  • TelePresence
1 ACCEPTED SOLUTION
You could activate DTMF navigation by pressing twice # on DTMF window.
Then you could use 8, 2, 4 and 6 keys ( for up, down, left and right ) for menu navigation.
Hope that help !
Valentin
Re: Jabber ipad for Telepresence Far End Camera Control for MCU
Yes, Jabber for IPad does support FECC, but it is not enable by default, you will have to enable FECC in provisioning directory configuration in TMS. Configure your provisioning template and set the parameter "Far end camera control" to On.
I hope this help.
Paulo Souza
Please rate replies and mark question as "answered" if applicable.
Paulo Souza Was my response helpful? Please rate useful replies and remember to mark any solved questions as "answered".
Hi ,
I enabled the feature in the template , but it did not help. How I can use the far end camera control on the iPad . It is not possible
To update the settings, you must to reprovision the client, just logout and login again. Have you done that?
Paulo Souza
We do not see an icon on the iPad for far end camera control or up/down/left/right arrows.  When/if enabled properly in the TMS, what do you TAP on the iPad screen to invoke the FECC?  We've downloaded the latest, 9.4.3 Cisco Jabber for iPad.
I just had a look at our work iPad2 and there is no FECC option available neither in enterprise version nor "free" version. (Enterprise version is being provisioned with FECC "On".)
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Hope that help !
Valentin
Perfect. It works :-)
I'm glad I could help you !
Works nicely for navigating a MCU menu, which was the original question, so +5 for that , but it ain't FECC - and it would be nice to have FECC in point-to-point calls. /shrug
/jens
1036
