08-09-2012 08:19 AM - edited 03-17-2019 11:35 PM
Hi all,
As recent trend of CUCM & VCS integration, our office has followed the same to build a SIP trunk betweem CUCM & SIP. I have checked IPphone from CUCM side can call to video endpoint successfully, but there is loop detected on the call from video endpoint registered to VCSc to IPphone.
Is there anyone can tell what Loop detected means? What I should check to investigate the issue? Please help kindly advise.
Below is the call search log:
VCS to CUCM | CUCM to VCS |
Search (15) State: Completed Found: False Reason: Loop detected Type: H323 (LRQ) CallSerial Number: 3ee834d0-e231-11e1-9a3e-0010f316eb04 Tag: 3ee83606-e231-11e1-8dc9-0010f316eb04 StartTime: 2012-08-09 22:48:13 Duration: 1.24 Source (1) Authenticated: False Aliases (1) Alias (1) Type: H323Id Origin: Unknown Value: 29315101 Zone (1) Name: DefaultZone Type: Default Destination (1) Alias (1) Type: H323Id Origin: Unknown Value: 29531403 SubSearch (1) Type: Transforms Action: Not Transformed ResultAlias (1) Type: H323Id Origin: Unknown Value: 29531403 SubSearch (1) Type: Admin Policy Action: Proxy ResultAlias (1) Type: H323Id Origin: Unknown Value: 29531403 SubSearch (1) Type: FindMe Action: Proxy ResultAlias (1) Type: H323Id Origin: Unknown Value: 29531403 SubSearch (1) Type: Search Rules SearchRule (2) Name: LocalZone Match1 Zone (1) Name: LocalZone Type: Local Protocol: H323 Found: False Reason: Not Found Gatekeeper (1) Address: 172.30.88.21:0 Alias (1) Type: H323Id Origin: Unknown Value: 29531403 Zone (2) Name: LocalZone Type: Local Protocol: SIP Found: False Reason: Not Found Gatekeeper (1) Address: 172.30.88.21:0 Alias (1) Type: H323Id Origin: Unknown Value: 29531403 SearchRule (3) Name: Zone001 Match1 Zone (1) Name: VF Corporation VCS Type: Neighbor Protocol: H323 Found: False Reason: Loop detected Gatekeeper (1) Address: 10.1.48.21:1719 Alias (1) Type: H323Id Origin: Unknown Value: 29531403 Zone (2) Name: VF Corporation VCS Type: Neighbor Protocol: SIP Found: False Reason: Internal Server Error Gatekeeper (1) Address: 10.1.48.21:5060 Alias (1) Type: H323Id Origin: Unknown Value: 29531403 SearchRule (4) Name: Zone003 Match1 Zone (1) Name: VEBBVCS1 Type: Neighbor Protocol: H323 Found: False Reason: Loop detected Gatekeeper (1) Address: 172.20.104.21:1719 Alias (1) Type: H323Id Origin: Unknown Value: 29531403 Zone (2) Name: VEBBVCS1 Type: Neighbor Protocol: SIP Found: False Reason: Internal Server Error Gatekeeper (1) Address: 172.20.104.21:5060 Alias (1) Type: H323Id Origin: Unknown Value: 29531403 SearchRule (5) Name: Zone004 Match1 Zone (1) Name: VEBB7EXW7 Type: TraversalClient Protocol: H323 Found: False Reason: Destination not found Gatekeeper (1) Address: 212.123.3.175:6001 Alias (1) Type: H323Id Origin: Unknown Value: 29531403 | Search (16) State: Completed Found: True Type: H323 (LRQ) CallRouted: True CallSerial Number: e650782e-e234-11e1-9eb5-0010f316eb04 Tag: e6507964-e234-11e1-a696-0010f316eb04 StartTime: 2012-08-09 23:14:22 Duration: 0.01 Source (1) Authenticated: False Aliases (1) Alias (1) Type: H323Id Origin: Unknown Value: 29531403 Zone (1) Name: CUCM Neighbor Type: Neighbor Destination (1) Alias (1) Type: H323Id Origin: Unknown Value: 29315101 SubSearch (1) Type: Transforms Action: Not Transformed ResultAlias (1) Type: H323Id Origin: Unknown Value: 29315101 SubSearch (1) Type: Admin Policy Action: Proxy ResultAlias (1) Type: H323Id Origin: Unknown Value: 29315101 SubSearch (1) Type: FindMe Action: Proxy ResultAlias (1) Type: H323Id Origin: Unknown Value: 29315101 SubSearch (1) Type: Search Rules SearchRule (2) Name: LocalZone Match1 Zone (1) Name: LocalZone Type: Local Protocol: H323 Found: True Gatekeeper (1) Address: 172.30.88.21:0 Alias (1) Type: H323Id Origin: Unknown Value: 29315101 |
08-09-2012 08:44 AM
Hi Bell,
The VCS has capability to detect the call as getting looped to stop to use all the resources for a single call.
for e.g. consider a scenario you make a call and you have a nieghbour zone betweev two VCS.
Endpt-->VCS-A<-->VCS-B<--Endpt
now you made a call. the request goes to VCS-A. it checks search rules and sends calls to VCS-B and because of wrong call routing the VCS-B sends the call back to VCS-A.
now VCS-A has a loop detection option!! if its ON it will come to know its the same call coming back to it which VCS-A has sent to VCS-B. at this point VCS-A can go on to match other search rules or it can drop the call based on subsequent search rules created on VCS.
This is related to search rules configured on the VCS and the priority and the Regex basically you are matching.
in your deployment you can fix the issue after modifying the searh rules and matching proper Regex!!
Alok
