MCU 4501 H323 Gatekeeper Problem!
Hello  cisco world Ii'm new and i hope that with your help i will soon be able to work with the VCS and the MCU
The problem is
I cannot register the h323 to the VCS
h323 gatekeeper : Enabled
h323 gatekeeper address : the address of the vcs
gatekeeper reg type : mcu standard
mandatory h323 id to register : mcuatprobadotbg
password :empty
and the other fields are empty
in the SIP page everything is OK and it is with status Registered but on the h323 page the results are :
h323 gatekeeper status name resolved to the ip of the vcs
Registered address  not registered
Alternate gatekeeper available  0
Thanks !
2 ACCEPTED SOLUTIONS
Hello Svetoslav
What do you see in VCS log ?
Status>Logs>Event log
br Oleksandr
br Oleksandr
Ok.
First, you need setup properly NTP on VCS and MCU
br Oleksandr
br Oleksandr
Hello Svetoslav
br Oleksandr
br Oleksandr
Zdrastvuvai Hello my friend
this is what i get
2013-08-06T17:24:13+03:00tvcs: Event="Registration Rejected" Reason="Time difference too large for authentication" Service="H323" Src-ip="192.168.1.221" Src-port="2222" Dst-alias-type="H323" Dst-alias="mcu@proba.bg" Protocol="UDP" Level="1" UTCTime="2013-08-06 14:24:13,194"
Ok.
br Oleksandr
br Oleksandr
Thanks mate tomorrow i will try and write what happened.
Thanks a lot problem solved! I reconfigured the NTP server and some other stuff and it worked thanks again!
337
