07-20-2012 04:55 AM - edited 03-17-2019 11:29 PM
I created a permanent conference at MCU and added to preconfigured participant which is couple defined endoints.
I setup Invite pre-configured participants field as "When at least one other participant is present".
When I call this conference number Mcu calling other preconfigured participant. All is ok.
But Mcu calling other enpoints with Mcu registration caller id.
Can I setup caller Id as conference name or number when Mcu calling preconfigured participant.
Baris.
07-23-2012 09:38 PM
If you enable" Use conference name as caller ID" check box on the confernece settings page it will use the confernce name as the caller ID
Garvan
07-24-2012 12:27 AM
Hello Garvan,
Thank you for relpy.
I tried before this option but It is not worked. I coudn't see any difference. Is there need more anthing about that ?
Baris.
07-24-2012 01:00 AM
Hello Garvan,
I want to add something here. My colleague using MSE 8510 chassis MCU.
It is working with his system. But I am using MCU 4505 with latest software but It doesn't work with us.
Is there any MCU 4505 user here ?
Baris.
