Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
MCU SIP Registrar
Dear
I have a CUCM 9.1, MCU, CUP,& sip ip phones
I want to understand what is SIP registrar in MCU, I have  read the guide but it is not clear for me.Anybody can give a short brief how it will be useful with my devices.
The SIP registrar is used to
The SIP registrar is used to allow the MCU to make and receive calls using SIP. In traditional video the MCU would register to the VCS Control. The MCU is really just a destination for multiparty calls. With additional video applications/appliances the MCU can be a dial out participant.
Dears, To allow conference
Dears,
To allow conference participants with SIP endpoints to connect to the MCU by dialing a directory number rather than an IP address, you must configure a SIP registrar. the MCU's interact with the SIP registrar and with SIP endpoints. The MCU can register up to 50 URIs with the SIP Registrar. This limit includes all conference Numeric IDs and the MCU's own URI
In my device who will be SIP registrar ??? and what will sip registrar domain, username and password,allow numeric ID registration for conferences
MCU needs registering itself
MCU needs registering itself to CUCM or VCS-C. Each MCU's  port behaves either as a sip B2BUA or as a H.323 MCU port.
https://www.facebook.com/groups/videoconferencing/ Raising funds for H323meeting.com, please contact me for details.
It is always handy if you
It is always handy if you would mention what kind of MCU you are talking about, like if its a Cisco/Tandberg/Codian style of MCU or something else and anyhow which type.
Also which documentation do you refer to? the exact document and place where you found
it is also helpful to get to the point what you saw and if thats imporant for your kind of deployment.
You just mentioned "ip phones". Are they Video capable or what are your video endpoints.
If you think of telephone conferences, an MCU might be overkill here and there are better
ways to handle phone only conferences.
If you refer to a Cisco/Tandberg/Codian style of MCU,
if I recall it right the 9.1 version does not use registrations towards CUCM, it simply uses a
SIP trunk:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/9_1_1/ccmcfg/CUCM_BK_A34970C5_00_admin-guide-91/CUCM_BK_A34970C5_00_admin-guide-91_chapter_0110101.html#CUCM_RF_C2CBC7F2_00
The MCU can be used in different environments, it can use sip trunks, then more or
less the other side of the trunk defines on what is send over to the MCU (like in the CUCM case)
or the MCU can register its addresses to a SIP registrar (for example on the VCS or any other SIP
Registrar).
In short it defines on how the call control knows what to send to the MCU.
Dear Martin,It is a cisco
Dear Martin,
It is a cisco MCU
I have following cisco tele presence deployment guide.
Sx20 endpoint and jabber softphones
you have forwarded me the link where it shows me that the MCU is registering to CUCM
The MCU can be used in different environments, it can use sip trunks, then more or less the other side of the trunk defines on what is send over to the MCU,
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/mcu/install_guide/mcu_deployment_guide_4-4.pdf
In the above link it is also registered as conference bridge and a rendezvous point also,
so just want to know the trunk is configured between CUCM and MCU and the route-pattern is configured, is it so it is configured for Meet-me rendezvous conferences
343
