Mobile and Remote Access using Cisco VCS Expressway-C and Expressway-E
Hi I have installed the Cisco VCS Expressway - E and Expressway -C.
I´m having issues in the TLS communication between the Cisco Callmanager and the VCS Control.
Also, between the VCS Control and the VCS Expressway.
I think is a problem of certificates.
Is there a video to follow? Because it´s very tricky trying to configure this part of the certificates.
I would recomend to check
I would recomend to check out
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-1/Cisco-Expressway-Certificate-Creation-and-Use-Deployment-Guide-X8-1.pdf
Most likely the most important part is that the used domains are correct and that its a client server certificate.
Not sure if a video would really help here ;-)
There is one for the cisco  webex integration, but that might not completely fit here:
http://www.cisco.com/c/en/us/td/docs/telepresence/infrastructure/tms/config_guide/webex_enabled_telepresence/config_vcse_certs/vcse_certs_part_1.html
Thanks for the links Martin!!
Thanks for the links Martin!! I will try to do it!
Hi,Is it mandatory to join
Is it mandatory to join the CUCM cluster to the Domain,DNS?
Hi!I don´t know if it is
Hi!
I don´t know if it is mandatory! But is better if you have all your devices configured in a domain with the proper DNS.
Regards.
324
