Monitor room trough C20 camera
Recently I receive a request, to verify if is possible to monitor a room trough the Tandberg C20 installed there.
I dont know if that is even possible, but if some one have an idea of how to do it (may be using a application, the HTTP site of the C20, etc)
Thank for your comments !!!!!
Everyone's tags (2)
1 ACCEPTED SOLUTION
If WebSnapshot is enabled you can request a thumbnail photo of the room via the HTTP interface, the admin GUI exposes this under Call Control for example.
Note that this configuration element cannot be remotely enabled, at least not easily, but once enabled can be remotely used (for security reasons).
Hi Frederick,
Thanks for your comment, it worked great, exactly what I was looking for !!!
331
