Multisite Feature Cisco C90, MX300 and SX20
Hello Everyone,
Anybody has information about how install Licenses Multisite L-C90-MS, LIC-MX300-MS and LIC-SX20-MS?  These ones are directly installed in the codec? how is the procedure?
Thanks a lot!!
1 ACCEPTED SOLUTION
Mario, These are option keys
Mario,
These are option keys that you will add directly to the codec. Just go to Maintenance>Upgrade and paste the option key into the option key field. This usually requires a reboot when done.
Adam
Mario,
Adam
VIP Green
It depends on how you receive
It depends on how you receive your licence key.
Usually, they come as a PAK - you need to register this on the Cisco Licencing Portal and assign the PAK to a specific endpoint.  From this, you will then get the Licence Key (1M003-1-XXXXXXXX).
This Licence Key you can enter in to your endpoint - On the Web Interface, Go to Maintenance > Software Upgrade and put the key in the "Option Key" field and click the "Add" button.
You can also do it from the Command Line Interface with the xcommand SystemUnit OptionKey Add Key: command.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
VIP Purple
Here is a document that shows
Here is a document that shows how to add the keys into the codec.
entering-licensing-mxp-and-tc-series-tandberg-endpointspdf
393
