need help in Tndberg
Dear,
I have a    Tandberg MXP  1000  (video-conference),  I did a hard reset on
it to fix problem.
but now ,we can not make a call , an error message appears:
"network option is missing "
"please install  a network bandwidth option "
after I installed " Tandberg MXP Software Upgrade" (s50000f9_0_2.pkg)
he ask me to enter the :
-new option key
-new bandwidth key
knowing that:
Software Version        F9.0 PAL
Hardware Serial Number  13A40709
what i can do with this if you have any solution .I'll be very grateful if
you help me on this.
thanks  .
Best Regards.
1 REPLY
Check you PM inbox
In future before doing a factory reset on a unit make note of all the option keys currently loaded on the systems.
Or email - Licensing@cisco.com
343
