Never seen arifacts during a video conference need help
                   I have  HDX8000 and a C90  in a conference call on a 4510 Codian Bridge we are seeing a cloudy white arifact covering the Lower third of our Display this happens throughout the conference sporadically and only lasts for a half a second and then goes away though it is unacceptable  by management All  units are at the latest code rev  It hapens 95% of the time on the users display that sees the C90 video
  • TelePresence
1 REPLY
Most comon issues are, things like, packet loss, wrong MCU size high jitter, to high bandwidth usage on a slow link, ...
Could you check on the MCU, endpopoints, call control (vcs, ..) how the call/media statistics look like?
Any network statistics availalbe? Always good to look into.
Which MCU software do you run? (I would run the latest).
Also check on the fw versions of the other involved components.
Which media-codecs, which bandwith is used?
Does it happen with other locations or point to point calls as well?
If its multiple users seeing the same behavior coming from a specific endpoint like that C90 I would start
checking the path in between the C90 and the MCU.
310
