Operating System ?
On which operating system all Telepresence system (C60, MX300, MXP seriers), MCU, VCS, TCS runs.
1 ACCEPTED SOLUTION
VIP Green
Operating System ?
As Jens has said above, yes, the TCS (TelePresence Content Server) runs on a Windows platform, and so does TMS (TelePresence Management Suite).  They're effectively just applications that run on top of the Windows OS.
The C60/EX90/etc devices that run the TC series software are Linux based - you can check this if you look in the logs when logged in as root (ie, on a TC7.0.2 box: Linux version 3.9.11-238 (henribak@rdbuild14) (gcc version 4.7.2 (crosstool-NG hg+default-20f2459b97bf) ) #1 PREEMPT Mon Jan 13 13:53:18 CET 2014).
The VCSes also run a Linux based OS (ie, on Software version X8.1 it's: Linux version 3.6.1 (jenkins@ukdev-natty-build3) (gcc version 4.7.2 (GCC) ) #1 SMP Tue Nov 26 12:08:07 UTC 2013).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Operating System ?
TCS runs on Windows servers, I believe the MXPs are running eCos, not sure about the rest, but suspect the C-series and VCS could be using a custom Linux solution.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
VIP Green
Operating System ?
Wayne
Wayne
Hi Wayne,
Hi Wayne,
How to check the Linux version of the Cisco VCS/Expressway? We are running on software version X8.8.
Thank you.
VIP Green
If you telnet/ssh/serial
If you telnet/ssh/serial connect to your VCS and log in as root, you can issue the uname -a command which will show you which version.  Here's a sample from X8.1.1:
Linux hostname 4.4.3 #1 SMP Thu Jun 30 11:59:49 UTC 2016 x86_64 GNU/Linux
Wayne
Wayne
VIP Purple
[+5]
[+5]
uname -a helped me to get OS
regds,
aman
Operating System ?
664
