Community Member
Outbound calls are not connecting to the VCSE(from cisco endpoints)
Hello Team,
Using single interface deployment of VCS-C and VCS-E ,
Outbound calls are not connecting to the VCSE(from cisco endpoints),but if we are using polycom endpoints calls landing successfully.
VCSE having static Nat ip Address.
Please suggest the same and Waiting to hear from you all
Thanks for the Advance
Renji
I have no idea as to why
I have no idea as to why calls from Polycom endpoints works.....however, you must have dual-nic option key installed on the VCS-E when using NAT. This has been explained and documented time after time in this forum.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
In addiitonal to what Jens
In addiitonal to what Jens says, if you want to use the single interface on the VCS-E, you will have to have a public IP address assigned and routed directly to the the VCS-E. The VCS-C can be NAT'ed.
42
