Outbound Video calls not working from VCS Control to Expresway
paul alves
Level 4
Level 4
Hi All,
I've trying to make outbound video calls to test sites and other 3rd party video systems and I'm unable to get any outbound calls working.
Inbound calls work fine, no issues there at all.
I'm getting namely "NOT FOUND" or "Request Timeout" errors in the VCSE logs (I know the end points I'm trying to call are working as I can reach them with other 3rd party SIP products).
I'm going to see if there are any SIP/H323 "fixup" type settings on the firewall.
In addition, I do have a Dual Network option key installed, but its not cabled for the dual option (not certain this may be causing the issue or not), I don't need it so I'm not using it.
Its a basic config, single VCS control on the inside and single VCS Expressway on the outside (with Public IP Address) and only a single interface cabled. The outside interface is in the clear (no firewall in front of it).
Here's a couple examples of the logs taken from the VCSE
(this call was a movi user connected from the internet)
tvcs: Event="Call Rejected" Service="SIP" Src-ip="x.x.x.x" Src-port="53268" Src-alias-type="SIP" Src-alias="sip:user.movi@domain.com" Dst-alias-type="SIP" Dst-alias="sip:loopback.sip@cisco.com" Call-serial-number="d17985da-e644-11e1-b39b-0010f323814a" Tag="d17986c0-e644-11e1-a46f-0010f323814a" Detail="Not found" Protocol="TLS" Response-code="404" Level="1" UTCTime="2012-08-14 19:18:34,801"
and
This call was a dual profile 55 on the inside of the network making an outbound call to a user on the internet using the Cisco Jabber video software (movi, jabber.com)
Aug 14 14:50:50tvcs: Event="Call Rejected" Service="SIP" Src-ip="IP_of_VCS_Control" Src-port="25153" Src-alias-type="SIP" Src-alias="sip:5005@domain.com" Dst-alias-type="SIP" Dst-alias="sip:user@jabber.com" Call-serial-number="411dc2bc-e649-11e1-afaf-0010f323814a" Tag="41e14408-e649-11e1-9d51-0010f32305ae" Detail="Request Timeout" Protocol="TLS" Response-code="408" Level="1" UTCTime="2012-08-14 19:50:50,826"
The IP Address of the VCS control is listed as the source IP (not sure this is normal or not).
Note: I removed names/ip addresses for security reasons.
Any ideas?
thanks,
Paul
12 Replies 12
awinter2
Level 7
Level 7
Paul,
checking that inspection/fixup is disabled for SIP and H323 is always a good initial troubleshooting step.
As for the log entries you provided, the first entry shows a call to loopback.sip@cisco.com, and the response code for that call is 404 Not found, which could for example be caused by a lack of a DNS zone on your Expressway. A 404 response can in many cases be a completely legit and expected response.
The second log entry indicates that there seemingly isn't any NAT between your VCS Control and the Expressway, since the source address is shown as the actual IP address of the VCS Control (According to what you describe).
Can you confirm that your network routing allows the VCS-E to reach the subnet of the VCS-C through the default gateway that is configured on the VCS-E, and that traffic sent from the VCS-C to the VCS-E is actually being routed through the router which is acting as the default gateway for the VCS-E?
If not, then you might have an asymmetric routing problem which could explain the 408 Request timeout response which you are seeing in your logs. 408 Request timeout is a response which you normally shouldn't be seeing in a healthy network (Assuming the network configuration on your VCS's is correct).
- Andreas
Hi All,
Greetings !!
From SX20 telepresence unit, I am able to receive calls but cannot dial outside calls.
Please can anyone help in identifying the issue and resolve it
below are the logs and config for your reference or vcs c and e
Logs in VCS-C:
State Connection Failed
Start time 2017-06-14 12:52:29
End time 2017-06-14 12:53:27
Duration 58 seconds
Tag 71343458-a756-45b5-a6ed-a2857c413c82
Serial number 6565b4e0-d62d-4b0a-9447-9294bf2ac49c
Type Video
SIP variant Standards-based
Bandwidth
Requested 384 kbps
Allocated 384 kbps
Route CUCM Neighbor -> Zone001ToTraversalSZ -> TraversalSubZone -> Zone004ToTraversalSZ -> Traversal Zone
Leg 1
Bandwidth node CUCM Neighbor
Source alias 1 sip:123@10.30.27.15 (Url)
Target alias 1 sip:709@kdcc.com (Url)
Protocol SIP
Address 10.30.27.15:5070
Transport TCP
Reason Not found
Cause 404
Leg 2
Bandwidth node Traversal Zone
Protocol SIP
Address 10.30.27.19:7002
Transport TLS
Encryption type None
Leg 3
Target alias 1 709@kdcc.com (H323Id)
Protocol H323
Address 10.30.27.19:6001
Reason Not registered
Cause Destination not found
Session 1
Status Failed
Media routed True
Call routed True
Participant 1 Leg 1
Participant 2 Leg 2
Bandwidth allocated 384 kbps
Bandwidth requested 384 kbps
Session 2
Status Failed
Media routed True
Call routed True
Participant 1 Leg 1
Participant 2 Leg 3
  • Search (16)
    • State: Completed
    • Found: False
    • Reason: Not Found
    • Info: Policy Response
    • Type: SIP (INVITE)
    • SIPVariant: Standards-based
    • CallSerial Number: 6565b4e0-d62d-4b0a-9447-9294bf2ac49c
    • Tag: 71343458-a756-45b5-a6ed-a2857c413c82
    • Source (1)
      • Authenticated: False
      • Aliases (1)
        • Alias (1)
          • Type: Url
          • Origin: Unknown
          • Value: 123@10.30.27.15
      • Zone (1)
        • Name: CUCM Neighbor
        • Type: Neighbor
      • Path (1)
        • Hop (1)
          • Address: 10.30.27.15:5070
    • Destination (1)
      • Alias (1)
        • Type: Url
        • Origin: Unknown
        • Value: sip:709@kdcc.com
    • StartTime: 2017-06-14 12:52:29
    • Duration: 58.26
    • SubSearch (1)
      • Type: Transforms
      • Action: Not Transformed
      • ResultAlias (1)
        • Type: Url
        • Origin: Unknown
        • Value: 709@kdcc.com
      • SubSearch (1)
        • Type: Admin Policy
        • Action: Proxy
        • ResultAlias (1)
          • Type: Url
          • Origin: Unknown
        • SubSearch (1)
          • Type: FindMe
          • Action: Proxy
          • ResultAlias (1)
            • Type: Url
            • Origin: Unknown
          • SubSearch (1)
            • Type: Search Rules
            • SearchRule (1)
              • Name: Traversal zone search rule
              • Zone (1)
                • Name: Traversal Zone
                • Type: TraversalClient
                • Protocol: SIP
                • Found: False
                • Reason: Not Found
                • Duration: 38.12
                • Gatekeeper (1)
                  • Address: 10.30.27.19:7002
                  • Alias (1)
                    • Type: Url
                    • Origin: Unknown
              • Zone (2)
                • Protocol: H323
                • Found: False
                • Reason: Not registered - Destination not found
                • StartTime: 2017-06-14 12:53:07
                • Duration: 20.13
                • Gatekeeper (1)
                  • Address: 10.30.27.19:6001
                  • Alias (1)
                    • Type: Url
                    • Origin: Unknown
1 Route to CUCM Any Any No Alias pattern match Regex (.*)@gulfsls.com Replace Stop CUCM Neighbor Any   View/Edit | Clone
2 Local Zone - No domain Any Any No Alias pattern match Prefix (.+)@gulfsls.com.* Replace Continue LocalZone Any   View/Edit | Clone
5 LocalZoneMatch Any Any No Alias pattern match Regex (.+)@gulfsls.com.* Leave Continue LocalZone Any   View/Edit | Clone
10 Dial IP Address Search Rule Any Any No Any IP address Stop Traversal Zone Any   View/Edit | Clone
45 CEtcp-cucmadmin.gulfsls.com SIP Any No Alias pattern match Prefix cucmadmin.gulfsls.com;transport=TCP Leave Stop CEtcp-cucmadmin.gulfsls.com All SIP Variants   View | Clone
50 Route to CUCM Outside Any Any No Alias pattern match Regex ^(\d(8))@gulfsls.com(.*)$ Leave Stop CUCM Neighbor Any   View/Edit | Clone
90 External IP address search rule Any Any No Any IP address Continue Traversal Zone Any   View/Edit | Clone
100 Traversal zone search rule Any Any No Any alias Continue Traversal Zone Any   View/Edit | Clone
2 Enabled "Add domain where none exists" ([^@]*) Regex Replace \1@gulfsls.com View/Edit
5 Enabled Convert unified CM supplied domain information to Expressway (1\d{2})@vcse.gulfsls.com)(:.*)? Regex Replace \1@gulfsls.com View/Edit
13 Enabled Transform to strip domain from IP-address call (.*)\.(.*)\.(.*)\.(.*)@h323.gulfsls.com Regex Replace \1.\2.\3.\4 View/Edit
Logs in VCS-E:
End time 2017-06-14 12:53:07
Duration 38 seconds
Serial number 85679bc2-c38a-413a-a279-cf5a5a8cfe53
Type Video
Bandwidth
Requested 384 kbps
Allocated 384 kbps
Route Traversal Zone -> Zone003ToTraversalSZ -> TraversalSubZone -> Zone002ToTraversalSZ -> DNS Zone
Leg 1
Protocol SIP
Address 10.30.27.18:25031
Transport TLS
Reason Not found
Cause 404
Leg 2
Bandwidth node DNS Zone
Protocol SIP
Address 62.215.248.172:5061
Transport TLS
Leg 3
Protocol SIP
Address 62.215.248.172:5060
Transport TCP
Leg 4
Protocol SIP
Transport UDP
Leg 5
Protocol H323
Address 62.215.248.172:1719
Reason Undefined reason
Cause Request timeout
Session 1
Status Failed
Media routed True
Call routed True
Participant 1 Leg 1
Participant 2 Leg 2
Session 2
Status Failed
Media routed True
Call routed True
Participant 1 Leg 1
Participant 2 Leg 3
Session 3
Status Failed
Media routed True
Call routed True
Participant 1 Leg 1
Participant 2 Leg 4
Session 4
Status Failed
Media routed True
Call routed True
Participant 1 Leg 1
Participant 2 Leg 5
  • Search (16)
    • State: Completed
    • Found: False
    • Reason: Not Found
    • CallSerial Number: 85679bc2-c38a-413a-a279-cf5a5a8cfe53
    • Source (1)
      • Aliases (1)
        • Alias (1)
          • Type: Url
          • Origin: Unknown
      • Zone (1)
        • Type: TraversalServer
      • Path (1)
        • Hop (1)
          • Address: 10.30.27.18:5061
        • Hop (2)
    • Destination (1)
      • Alias (1)
        • Type: Url
        • Origin: Unknown
    • Duration: 38.11
    • SubSearch (1)
      • Type: Transforms
      • ResultAlias (1)
        • Type: Url
        • Origin: Unknown
      • SubSearch (1)
        • Action: Proxy
        • ResultAlias (1)
          • Type: Url
          • Origin: Unknown
        • SubSearch (1)
          • Type: FindMe
          • Action: Proxy
          • ResultAlias (1)
            • Type: Url
            • Origin: Unknown
          • SubSearch (1)
            • SearchRule (1)
              • Name: LocalZoneMatch
              • Zone (1)
                • Name: LocalZone
                • Type: Local
                • Protocol: SIP
                • Found: False
                • Reason: Not Found
                • Duration: 0
                • Gatekeeper (1)
                  • Address: 10.30.27.19:0
                  • Alias (1)
                    • Type: Url
                    • Origin: Unknown
              • Zone (2)
                • Name: LocalZone
                • Type: Local
                • Protocol: H323
                • Found: False
                • Reason: Not Found
                • Duration: 0
                • Gatekeeper (1)
                  • Alias (1)
                    • Type: Url
                    • Origin: Unknown
            • SearchRule (3)
              • Name: DNS Zone search rule
              • Zone (1)
                • Name: DNS Zone
                • Type: DNS
                • Protocol: SIP
                • Found: False
                • Reason: Request Timeout
                • Duration: 10.64
                • Gatekeeper (1)
                  • Alias (1)
                    • Type: Url
                    • Origin: Unknown
              • Zone (2)
                • Name: DNS Zone
                • Type: DNS
                • Protocol: H323
                • Found: False
                • Reason: Undefined reason - Request timeout
                • StartTime: 2017-06-14 12:52:50
                • Duration: 17.24
                • Gatekeeper (1)
                  • Alias (1)
                    • Type: Url
                    • Origin: Unknown
Priority Rule name Protocol Source Authentication required Mode Pattern type Pattern string Pattern behavior On match Target SIP variant Enabled Actions
50 LocalZoneMatch Any Any No Any alias Continue LocalZone Any   View/Edit | Clone
100 Traversal Search Rule Any Any No Any alias Continue Traversal Zone Any   View/Edit | Clone
150 DNS Zone search rule Any All zones No Alias pattern match Regex (?!.*@gulfsls.com.*$).* Leave Continue DNS Zone Any   View/Edit | Clone
Priority State Description Pattern Type Behavior Replace Actions
1 Enabled Transform destination aliases to URI format ([^@]*) Regex Replace \1@gulfsls.com View/Edit
Martin Koch
you can limit some generic mistakes by checking out:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Basic_Configuration_Cisco_VCS_Control_with_Cisco_VCS_Expressway_Deployment_Guide_X7-1.pdf
Than would look into:
* do you have a dns zone
* do you have a search rule hitting that zone
* can you resolve dns from the vcs-e (see screenshot on how to test it)
under maintenance / tools you can also find the locate tool. Try that with loopback@cisco.com and copy paste the result here.
You should see a green True somewhere like:
If all this did not help,
  • does it make a difference if you use h323 to initiate the call?
  • How does the search history of failed real calls look like.
  • Check your firewall / routes
  • Do network traces, check logs, enable debugging and analyze it.
  • Call your Cisco TelePresence partner for help!
Here's a failed call detail
151.124.146.111 = Real dual 55 profile IP on internal network
205.214.144.152 = VCSE Public IP Address
Call details
You are here:Status Calls Calls Call details
Call information
State
Connection Failed
Start time
2012-08-14 22:29:07
Duration
38 seconds
Tag
5ed43ae4-e689-11e1-b15c-0010f32305ae
Serial number
5ed439fe-e689-11e1-88cd-0010f32305ae
Bandwidth
Requested
6000 kbps
Allocated
6000 kbps
Route
DefaultSubZone -> DefaultSZtoTraversalSZ -> TraversalSubZone -> Zone001ToTraversalSZ -> TraversalZone
Leg 1
Bandwidth node
Default Subzone
Source alias 1
sip:source@domain.com (Url)
Target alias 1
sip:loopback.sip@cisco.com (Url)
Protocol
SIP
Address
151.124.146.111:5060
Transport
UDP
Reason
Request Timeout
Cause
408
Leg 2
Bandwidth node
TraversalZone
Source alias 1
Target alias 1
Protocol
SIP
Address
205.214.144.152:7001
Transport
TLS
Encryption type
None
Leg 3
Bandwidth node
TraversalZone
Target alias 1
loopback.sip@cisco.com (H323Id)
Protocol
H323
Address
205.214.144.152:6001
Reason
Undefined reason
Cause
Request timeout
Session 1
Status
Failed
Media routed
True
Call routed
True
Participant 1
Leg 1
Participant 2
Leg 2
Bandwidth allocated
6000 kbps
Bandwidth requested
6000 kbps
Route
Channel 0
Type
Audio
Protocol
PCMU
Rate
0 bps
Packets forwarded
Keepalives
Errors
Duplicate packets
Lost packets
Out of order packets
Jitter
0 ms
From
Channel 1
Type
Video
Protocol
PCMU
Rate
0 bps
Packets forwarded
Keepalives
Errors
Duplicate packets
Lost packets
Jitter
0 ms
From
Channel 2
Type
Application
Protocol
BFCP
Rate
0 bps
Packets forwarded
Keepalives
Errors
Duplicate packets
Lost packets
Jitter
0 ms
From
Channel 3
Type
Unknown
Protocol
UNKNOWN
Rate
0 bps
Packets forwarded
Keepalives
Errors
Duplicate packets
Lost packets
Jitter
0 ms
From
Channel 4
Type
Application
Protocol
H224
Rate
0 bps
Packets forwarded
Keepalives
Errors
Duplicate packets
Lost packets
Jitter
0 ms
From
Session 2
Status
Failed
Media routed
True
Call routed
True
Participant 1
Leg 1
Participant 2
Leg 3
Bandwidth allocated
5952 kbps
Bandwidth requested
5952 kbps
Route
I have the DNS Zone and I was able to resolve DNS names using the DNS tool
Using Tools/Locate from the VCS Control (endpoint registerd to the VCS Control)
  • Search (1)
  • State: Searching
  • Found: False
  • Type: SIP (OPTIONS)
  • CallSerial Number: f85ee00e-e68b-11e1-865d-0010f32305ae
  • Tag: f85ee130-e68b-11e1-bde6-0010f32305ae
  • StartTime: 2012-08-14 22:47:43
  • Source (1)
    • Authenticated: True
    • Aliases (1)
      • Alias (1)
        • Type: Url
        • Origin: Unknown
        • Value: xcom-locate
    • Zone (1)
      • Name: DefaultZone
      • Type: Default
    • Path (1)
      • Hop (1)
        • Address: 127.0.0.1
  • SubSearch (1)
    • Type: Transforms
    • SubSearch (1)
      • Action: Proxy
      • SubSearch (1)
        • Type: FindMe
        • Action: Proxy
        • SubSearch (1)
          • SearchRule (1)
            • Name: Traversal Zone Search Rule
            • Zone (1)
              • Name: TraversalZone
              • Protocol: SIP
              • Found: False
Using Tools/Locate on the VCSE (not sure which source zone to use, used the Traversal Zone).
Note: IP Address 127.0.0.1 is the IP on the 2nd NIC on the VCSE (Its licensed for Dual NICs, but I'm not using Dual NICs).
The Ethernet interface has a public IP Address and directly connected to the internet.
Search completed.
  • Search (8)
    • State: Completed
    • Found: False
    • CallSerial Number: 5e67a128-e6f6-11e1-a0a1-0010f323814a
    • Tag: 5e67a20e-e6f6-11e1-b727-0010f323814a
    • StartTime: 2012-08-15 11:29:21
    • Duration: 20.56
    • Source (1)
      • Aliases (1)
        • Alias (1)
          • Type: Url
          • Origin: Unknown
      • Zone (1)
      • Path (1)
        • Hop (1)
    • SubSearch (1)
      • Type: Transforms
      • SubSearch (1)
        • Action: Proxy
        • SubSearch (1)
          • Type: FindMe
          • Action: Proxy
          • SubSearch (1)
            • SearchRule (2)
              • Name: DNS Zone Search Rule
              • Zone (1)
                • Name: DNSZone
                • Type: DNS
                • Protocol: SIP
                • Found: False
I have the feeling you did not really follow the standard deployment
I do not really see that the DNS zone is hit at all by your search, so there is most likely something wrong with your
dns zone, search rules or transforms.
Also do you expect to find "loopback.sip@cisco.com" on the second search I only see loopback.sip@compucom.com
To be honest, this looks like the typical "if you know how it shall work its fixed in no time." issue.
The back and forth in the forum is not really helpful, a hands on check would be way easier.
If you can not fix it yourself you should call your Cisco TelePresence partner and ask for help.
I accidentally typed in the wrong URI (meant cisco.com and not compucom.com). Compucom.com is the internal domain, so it wouldn't have searched/went to the DNS zone, that's why it appears the DNS zone wasn't hit.
I have set it up as per the guide you mentioned.
I edited my post with loopback.sip@cisco.com, back above, but here it is anyhow (from the VCSE from an internal endpoint), trying to reach the outside.
Search completed.
  • Search (8)
    • State: Completed
    • Found: False
    • Duration: 20.56
    • Source (1)
      • Aliases (1)
        • Alias (1)
          • Type: Url
          • Origin: Unknown
      • Zone (1)
      • Path (1)
        • Hop (1)
    • SubSearch (1)
      • Type: Transforms
      • SubSearch (1)
        • Action: Proxy
        • SubSearch (1)
          • Type: FindMe
          • Action: Proxy
          • SubSearch (1)
            • SearchRule (2)
              • Zone (1)
                • Name: DNSZone
                • Type: DNS
                • Protocol: SIP
                • Found: False
thanks,
Paul
yea, but then we are back to what I said in the early begining,
either it does not find the proper dns records, or your firewall is blocking or changing the request.
Hello there;
I receive the same error on Cisco expressway to me. call falls on iOS does not fall "Call Rejected" is. I get this error every time. can you help me get it.
Error log:
tvcs: Event="Call Rejected" Service="SIP" Src-ip="10.1.1.1" Src-port="10006" Src-alias-type="SIP" Src-alias="sip:5000@10.1.0.32" Dst-alias-type="SIP" Dst-alias="sip:04a27964-e582-4801-3f29-bcb59c30d91a@10.218.156.67" Call-serial-number="932f3edb-e32e-4011-a1ea-55f69d2895b3" Tag="d5121b51-6ef1-4b8e-9c4b-7ff0acc474c1" Detail="Request Terminated" Protocol="TLS" Response-code="487" Level="1" UTCTime="2016-03-15 14:04:46,217"
We are getting the same Response code="487"
Did you ever resolve this? Cisco TAC has not been helpful in this case.
Thanks. Jordan
Tomonori Taniguchi
Just quick check, do you have DNS zone and any search rule pointing DNS zone in VCS Control?
For external URI dialing, DNS lookup should be done at VCS Expressway.
If you have any search rule on VCS Control pointing DNS zone, please remove it and try making outgoing external call.
Hi Tomonori,
Thanks for your reply.
I do not have any DNS Zones or any search rules pointing DNS zone in the VCS Control.
The only places I have the DNS lookup for external URI dialing is on the VCS Expressway.
See below....
VCS Control
VCS Expressway
Here's the VCSE DNS Zone Configuration and Search Rule
DNS Search Rule
thanks,
Paul
