Phonebooks disappeared from scheduling interface after upgrading to TMS 14.5
Upgraded to TMS 14.5 this morning and now finding, to my great dismay - that none of my phone books are available in the drop-down menu in the Add Participants pop-up window - see attached screenshots.
All phone books are otherwise showing up correctly on the end-points, so I know they are still there...
These are the phone books, which were all correctly listed in the drop-down menu in all other versions of TMS:
This is what I now get:
Anybody else having this issue? If I can't resolve it, then I've got no choice but to downgrade to 14.4 :( (Lucky it's a VM so it's only a matter of applying the last snapshot).
Edit: I've managed to create a work-around by connecting all the phone book sources to the "All Systems: phone book, which means the support staff will at least be able to find the entries as long as they have an idea of what to search for. Far from ideal though. :(
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
Hm.... I can reproduce the
Hm.... I can reproduce the problem in 14.5. Looks like an unintentional side effect of some other stuff we were doing. I'll investigate more.
-Kjetil
Bug number: CSCur12429A fix
A fix is targeted for TMS 14.6.
VIP Purple
I checked my lab TMS, and my
I checked my lab TMS, and my phone books are present in the Add Participants window.
Something to check, what are the permissions set to for your missing phone books?
  • Manage Phone Books > "Phone Book" > Access Control > TMS User Group
We had an issue such as this not long ago, a certain group couldn't see the phone books to add participants, and it was a permissions issue on each missing phone book.
Checked the permissions and
Checked the permissions as soon as I discovered this, and they're fine. I've got, by default, access to absolutely everything anyway, being the system admin, and I couldn't see them either.
Reverted back to 14.4.1 and it's all good again, so I'll leave it at that for now. This was, strangely enough, the one and only issue I could find - everything else was fine.
/jens
VIP Purple
It's strange that you can see
It's strange that you can see "All Systems" and "Provisioning", but nothing else.  Maybe something somewhere is set differently between those two phone books and the others you're not seeing.
Don't know what that could be
Don't know what that could be since I'm the one who "sets the settings" so to speak, and everything worked perfectly prior to the upgrade. Applied a stack of "important" server updates from Microsoft just before upgrading TMS, wonder if something went astray there, but why would that only affect the phone books - that doesn't really make sense either. And remember, I can see all the phone books everywhere else, it's just in that drop-down menu they're MIA.
Only explanation I think of would be that one of the services didn't start properly, didn't have time to do much troubleshooting unfortunately, and won't be able to try again until the semester is over in another 6 weeks.
/jens
Hi,Are the phone book sources
Are the phone book sources configured as "Update Type: Search Only"? If so, they can no longer be scheduled in TMS 14.5. Try changing them to "Import to TMS".
Kjetil
Hei Kjetil,Only have that
Hei Kjetil,
Only have that option for the "All Systems" and "Provisioning" in 14.4.1 and it was the same in 14.5 - these options are otherwise not available. All of the phone books in question are manual lists types.
mvh
jens
-Kjetil
Thanks Kjetil, as always,
Thanks Kjetil, as always, very much appreciated. :)
mvh jens
Looks like a bug to me. I
Looks like a bug to me. I have filed a bug report, and will post the bug number as soon as I have a target for a fix.
-Kjetil
Thanks Kjetil :)mh jens
Thanks Kjetil :)
mh jens
Thanks Kjetil, Any news on
Thanks Kjetil,
Any news on when 14.6 is planned to be released?
Niklas
VIP Purple
I'm not sure if this is
I'm not sure if this is related, but comparing TMS 14.3.2 and TMS 14.5.  When you go to add participants in 14.5 and select "All Phone books" nothing appears, before it showed a compiled list of all phone books contained under that top group.
268
