Problem with multiway on C90
Hi all,
We have some problems with our C90 using Multiway.
We have some C20 and two C90, 2 VCS Control and one MCU 8510.
When I make a call between the C90 and one C20 all works fine, but when I try to add a new participant from the C90, the device freeze the image and close the connection.
We did a lot of test with different C20 using multiway and works fine.
Our C90s are running TC4.2.0.260857.
Somebody know what could be the problem??
Thank you
Juan Granata
Everyone's tags (3)
HI,
I think we need more details here.
To start with :
1. sw version on C90, VCS and 8510
2. can you dial from the C90 the multiway template directly and get connected to the MCU ? ( for example if you have set as template on your VCS : 450099%%@domain.net can you place calls from C90 directly to 45009900@domain.net and get connected without any problem to the MCU ? )
3. probably the best way to find out what's goin wrong here is to get a nelot 2 from VCS while reproducing the problem. Kindly asked to let me know if you are not fammiliar with the logging procedure on VCS and I'll send you more details
Cristian
In order to get the logs from VCS you need to :
1. open a telnet / ssh session with the VCS
2. type the following :
   xconfiguration
   xstatus
   netlog 2
3. reproduce the problem
4. type on telnet / ssh connection
   netlog 2
Provide us the logs and also if possible the endpoints details that were used to reproduce the issue
Sorry, I was to fast
at step 4 to turn off the logs you need to type "netlog off"
Cristian
811
