Problems writting CPL's
I am trying to write a CPL to block those pesky @asterisk calls and also create a hunt group but I am not having any luck.
Here's the example, any idea where I am going wrong?
The call blocking is fine, but think my formatting of the hunt group is wrong?
<?xml version="1.0" encoding="UTF-8"?>
<cpl xmlns="urn:ietf:params:xml:ns:cpl"  xmlns:taa="http://www.tandberg.net/cpl-extensions"  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"  xsi:schemaLocation="urn:ietf:params:xml:ns:cpl cpl.xsd">
<taa:routed>
    <!-- This CPL is intended to block scans / call attempts from asterisk@.* and 100@1.1.1.1 and unknown@.* -->
    <!-- changes / addons might be needed in your setup -->
  <taa:rule-switch>
     <!-- the next two lines block unauthenticated calls from asterisk and 100@1.1.1.1 -->
   <taa:rule unauthenticated-origin="asterisk@.*" destination=".*"><reject status="403"/></taa:rule>
   <taa:rule unauthenticated-origin="100@1.1.1.1" destination=".*"><reject status="403"/></taa:rule>
   <taa:rule unauthenticated-origin="unknown@.*" destination=".*"><reject status="403"/></taa:rule>
     <!-- the next two lines block authenticated calls from asterisk and 100@1.1.1.1 -->
   <taa:rule origin="asterisk@.*" destination=".*"><reject status="403" /></taa:rule>
   <taa:rule origin="100@1.1.1.1" destination=".*"><reject status="403" /></taa:rule>
   <taa:rule origin="unknown@.*" destination=".*"><reject status="403"/></taa:rule>
</taa:routed>
  </taa:rule-switch>
<address-switch field="destination">
<address is="thehuntgroupname">
<!-- call site 1 and site2 for 100 seconds
<location clear="yes" url="user1@domain.com">
<location clear="yes" url="user2@domain.com">
<proxy timeout="100">
<default>
</taa:rule-switch>
</taa:routed>
</cpl>
Rohan
Dear Rohan,
For more details about CPL and a very useful list of CPL examples you can consult the VCS admin, guide, the CPL refference setcion of the guide ( pages 335- 346) available at :
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/admin_guide/Cisco_VCS_Administrator_Guide_X7-0.pdf
You can also use as refference a good example of "ISDN overflow using CPL script" document available at :
http://www.tandberg.com/collateral/documentation/Deployment_Guides/Cisco_VCS_ISDN_Overflow_Using_CPL_Script_Application_Note.pdf
Kind regards
Cristian
Thanks for the reply Cristian.
I used those documents as the basis for the hunt group lines I wrote for that CPL. There's a section that states this:
user1@domain.com">
user2@domain.com">
Will create a forked call (similtaneous ring) which is what i need.
I think the main thing is I am not familier with XML or CPL scripting so think I may have some of the syntaxes wrong?
Can you try in the CPL,
instead of  :
from the syntax if I'm not wrong
Cristian
849
