Community Member
Provisioning and frequency synchronization
Is it possible to set frequency synchronization between TMS (TMSPE 1.1) and AD server? If yes, where can I found it?
I remember, it was possible some time ago. Now, I don't see this option.
This option is not, and I don't believe, has ever been possible. The task is scheduled to launch once a day, at 4 AM.
- Zac
Community Member
And is there any other way to do it more times than only one for day?
Re: Provisioning and frequency synchronization
There is no supported method of changing the frequency. Your only option is to run it manually at the other times you wish it to run.
250
