"Not SIP-registered to H320 peripheral" on C40 codec with ISDN Link
Dear Everyone
I got this error message from C40 codec with ISDN link.
How can I solve this issue.  C40 software version is TCNC702 and ISDN Link software version is IL1.1.0
Everyone's tags (1)
Hi, I looks like same issue I
I looks like same issue I got. TAC reported a bug on TC7, and TC7 is "not validated" with ISDN-link IL1.1.0.
IL1.1.1 is told to fix this.
Guillaume
Hi guillaume, Do you kown
Hi guillaume,
Do you kown when CISCO will release IL1.1.1 and can I have a work around at this moment?
Wink
Sorry Wink, I don't have any
Sorry Wink, I don't have any info about release date. Workaround was to keep TC 6.3...
Guillaume
VIP Green
In the ISDN Link
In the ISDN Link Configuration, under the Gateway Menu - set the SIP PeerHost to the IP address of the C40, and give it a SIP PeerUri.
Make sure you have IPv6 enabled on both the C40 and SX20 otherwise the pairing can fail.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
HelloI see you are running
Hello
I see you are running TCNC software. There is a current bug up for ISDN Link pairing issues with non encrypted codecs. TCNC = TelepresenceCodecNoCrypto
Try unpairing the ISDN Link and then upgrade the unit from TCNC 7.0.2 to TC 7.0.2 (requires a new release key for TC7)
Hope this helps.
Bug reference: CSCul19957 - ISDN Link 1.1 encryption mismatch, will not pair un-encrypted codec
Software fix targeted for TC7.2 (june timeframe, no gurantees on timeframe and fix version as this might be subjected to change)
/Magnus
We are having this same
We are having this same problem after a software upgrade to the latest firmware. We then rolled back to version 6.0.2 but this same issue is happening.Can anyone advise why the problem would continue after going back to a previous version that was working?
Would you advise a factory reset then re-apply the know working firmware version?
VIP Green
If you are using the "TC"
If you are using the "TC" software, there shouldn't be an issue - it's really only a problem with the "TCNC" software.
Make sure you have IPv6 enabled on both devices.
Running the more recent firmware on both may also help.  ie TC7.1.4 on the endpoint and IL1.1.2 or later on the ISDNLink.
Wayne
Wayne
507
