Registering a TelePresence CTS-MX200 on my network
Hi ONE MORE TIME, Guys.
I have an issue, that is to register and configure the TelePresence CTS-MX200 on my network.
I have a router with Call Manager Express (CME) 8.6 on it, the IP phones 9971 and the switches.
What are the requirements for a successful registration and installation of the TelePresence CTS-MX200?
What are the steps I should take?
My Server is SIP.
Any help i will be thankfull.
Thanks for your attention and time
-- Regards Edson Vuma
Everyone's tags (4)
What else is needed in order to install it?
Silver
Hi Edson,
I dont think you would be able to register MX200 to a CME. It is currently not tested. However, you can definitely try and check.
I have already mentioned the settings which you need to do. You can find my message in your inbox. I found some configurations missing in your the configurations you provided.
But I received your response that it is still not registering. Hence, I dont think we will be able to make it work since currently only CUCM is supported.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
OK, Thanks.
And whta should I do to install it using CUCM?
Thanks for your help.
Silver
You can follow the same steps as mentioned and specify the IP address of the CUCM as the SIP Proxy Server.
You will need to create a device profile and also make sure that the CUCM is on ver 8.6.2.
For more information, please refer to the following document :
http://www.cisco.com/en/US/docs/telepresence/endpoint/codec-c-series/tc5/administration_guide/administering_endpoints_running_tc5_on_cucm8-6.pdf
This would guide you in a step by step manner to register it on CUCM.
Mubashshir Akhtar
Sorry to ask, one more time, but how do i install the CUCM and where?
Mubashshir, are you there???
Silver
Hi Edson,
I am here. CUCM needs a special hardware to be installed and you would require a license to install it. Please refer to the following link for more info :
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_6_1/install/cmins861.html
Mubashshir Akhtar
Thanks...
But is it possible to download it?
778
