Bronze
Registering C40 to Avaya communication Manager using H.323
Has anyone been able to register a C40 (or C60 or C90) to an Aaya Aura Communication Manager 6.x, using the H.323 protocol?
I'm looking for a reference to know if it's been done before.
regards
Avner
1 REPLY
I'd suggest you just try to
I'd suggest you just try to fill in the fields in the configuration with valid details and see if it works. Did you try it or are you just asking if is possible? I would imagine i can be possible. Try old firmware on the C40.
301
