You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Registering C60 with VCS-C and EX90 withVCS-E
Can I know where what is the procedure to register a C60 with VCS-Control and procedure to register EX90 with VCS-E. I have created the user credentials for the EX90 in VCS-E. But i am not able to find where to configure that as EX90. Can you please direct me to some documentation link which breifs about it.
JK
  • TelePresence
1 REPLY
Re: Registering C60 with VCS-C and EX90 withVCS-E
Hi JK,
Quite easy, check the EX90 TC5.1 admin guide, this also works for the C60:
http://www.cisco.com/en/US/docs/telepresence/endpoint/ex-series/tc5/administration_guide/ex-series_administrator_guide_tc51.pdf
You can configure that on the tsh:
check:
"H323 Profile 1 Authentication" and "SIP Profile 1 Authentication" in the linked documentation if you need more info.
xconf SIP Profile 1 Authentication ?
*? xConfiguration SIP Profile [1..1] Authentication [1..1] LoginName: < 0="">
*? xConfiguration SIP Profile [1..1] Authentication [1..1] Password: < 0="">
xconf H323 Profile 1 Authentication ?
*? xConfiguration H323 Profile [1..1] Authentication LoginName: < 0="">
*? xConfiguration H323 Profile [1..1] Authentication Password: < 0="">
*? xConfiguration H323 Profile [1..1] Authentication Mode:
Regards the VCS, check the admin guide and the authentication guide might also be useful for you
as its also important to understand how the authentication itself on the VCS works:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/admin_guide/Cisco_VCS_Administrator_Guide_X7-1.pdf
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Authenticating_Devices_Deployment_Guide_X7-1.pdf
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Basic_Configuration_Cisco_VCS_Control_with_Cisco_VCS_Expressway_Deployment_Guide_X7-1.pdf
In general http://tandberg.com/docs is a good starting point regards Cisco TP documentation
Please rate this answer using the stars below the message!
1516
