Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Room Readiness Assessment Kit
Does anyone know who the company is that produces the TelePresence Room Readiness Assessment Kit?
I believe that they are in California - if anyone can provide details and hopefully a link I would be really grateful.
1 ACCEPTED SOLUTION
Hi James,
Pacific Radio Electronics
Maybe, there is a newer version available, but this is what I´ve ordered in 2009:
Tool Kit Part Number: PAC-CTS.RRAv1
Components of Tool Kit:
• NTI Acoustilyzer AL1 - Acoustic Analyzer and Tone Generating CD (Laptop or CD Player
required)
• NTI Mini SPL - Condenser Microphone to accompany Acoustic Analyzer
• NTI Minirator MR1 Tone Generator - Note: this item is Optional but recommended.
• Fostex 6301D - Portable Monitor Speaker (only one required)
• Cable to connect laptop and speaker - 1/4” TRS – 3.5mm TRS (at least 6 feet or 2 meters)
• Cable to connect Minirator MR1 to Speaker - 1/4” TRS – RCA (at least 6 feet or 2 meters)
• Extech 407026 Light Meter
• Carrying Case - Pelican 1510 with Pick’N’Pluck foam for a custom fit
cheers
Tino
Hi James,
required)
cheers
Tino
Tino,
Thanks - exactly what I needed to know
btw: I would recommend to use a Speaker with more Power. The Fostex is reaching it´s limit with RT60 Tests in bigger rooms.
1755
