SIP/2.0 404 Not Found
Need a sanity check on a design please, I think I already know the solution (another option key..) but wanted a second opinion.
Simple implementation of VCSc & VCSe, only difference to the norm is static NAT from the VCSc which has to be in-place due to reasons I won't go into on here.
VCSc                                     FW                                  VCSe
____________                              _______                                  ___________
|____________|  ----------------  |_______|  -------------------  |___________|
10.0.10.10   static NAT    > 10.255.1.1                          Public IP
Inside the network Movi works fine, outside I'm getting 404 policy responce, log below from the client.
2011-11-20 21:15:31,270 INFO PID 656 TID 3084 SIP
Outgoing SIP message: ---------------------------------------------
REGISTER sip:domain.com SIP/2.0
Via: SIP/2.0/TCP 192.168.1.1:3095;branch=z9hG4bK1634eac66a3ca8c5f19a2525a4752252.1;rport
Call-ID: 010b32545026eb6a@192.168.1.1
CSeq: 9001 REGISTER
Contact: <sip:user.movi@192.168.1.1:3095;transport=tcp>;+sip.instance="<urn:uuid:1c97dd7d-3b4c-5956-b53e-b18fccff9615>"
From: <sip:user.movi@domain.com>;tag=58e4b9e1d7b0270c
To: <sip:user.movi@domain.com>
Max-Forwards: 70
Route: <sip:VCSPUBLICIP:5060;lr>
Allow: INVITE,ACK,CANCEL,BYE,INFO,OPTIONS,REFER,NOTIFY
User-Agent: TANDBERG/771 (MCX 4.2.0.10318 (multistream))
Expires: 3600
Supported: replaces,100rel,timer,gruu
Content-Length: 0
2011-11-20 21:15:31,395 INFO PID 656 TID 3084 SIP
Incoming SIP message: ---------------------------------------------
Via: SIP/2.0/TCP 192.168.1.1:3095;branch=z9hG4bK1634eac66a3ca8c5f19a2525a4752252.1;received=82.12.29.2;rport=3095;ingress-zone=DefaultZone
CSeq: 9001 REGISTER
To: <sip:user.movi@domain.com>;tag=8bf2c0247045df7d
Server: TANDBERG/4102 (X7.0.2)
Warning: 399 VCSEPUBLICIP:5060 "Policy Response"
Content-Length: 0
Do I need the option key on the VCSc?
Message was edited by: Darren Goulden Just noticed the 'dual network' option is not available on the VCSc, what are my options if the NAT is interfering with the external provisioning?
Darren,
how are your movi users provisioned? local on the vcs?, or using tms?, also you see this message:
"Policy Response"
This is an error due to your zone credentials configuration...hence i will suggest you to check your zone
design.
I am assuming that your movi users are registering to your VCS instead of your VCSE right? if so then check your zone design and configuration between your VCS and VCSE.
Cesar Fiestas
Cesar Fiestas
Re: SIP/2.0 404 Not Found
Hi Cesar,
I thought that at first as I've had that issue on previous installations but all zones have been modified to different settings including 'treat as auth' on all.
Users are provisioned from TMS to the VCSc
Darren,
When I ask you to review the design and configuration of your zones, did you review the configuration of your search rules as well?, because your movi could be trying to register to your VCSE (defaultzone) instead of your VCSC, (assuming) that your provisioning configuration was set on your VCSC (based of the information you have provided your provisioning information resides on your VCSC), As such your movi users configuration/provisioning information "exist" in your VCSC rather than your VCSE, hence the failure here, since instead it seems that your VCSE is loooking on its defaultzone for this movi user provisioning information. Your VCSE instead it needs to conduct a search on your VCSC via your traversal zone using typically a traverzal zone search rule.
I will suggest you looking at this guide
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Basic_Configuration_Cisco_VCS_Control_with_Cisco_VCS_Expressway_Deployment_Guide_X7-0.pdf
Cesar Fiestas
Cesar Fiestas
Gold
Darren,
did you make sure to create the 'domain.com' SIP domain on the VCS-E in the VCS Configuration > Protocols > SIP > Domains page?
3363
