SQL 2005 to SQL 2008 R2 Update
Hey Everyone,
   I have a TMS (13.0) running on a dedicated Windows 2003 server and has the database hosted on one of our corporate servers running SQL 2005. All of the corporate SQL servers are getting migrated to 2008 R2 by the end of the summer. Has anyone done this type of migration with the TMS database and what issues or unexpected items came up?
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hello Steven
I'm assuming that you will be upgrading TMS to latest version as well (13.2).
As long if you follow procedure from documentation and verify all prerequisites and requirement all should go smooth.
Please check this link, especially page 16:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tms/install_guide/Cisco_TMS_install_guide_13-2.pdf
Also I  would strongly recommend to install TMSPE which will use SQL database instead of the OpenDS.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tmspe/install_guide/Cisco_TMSPE_Deployment_Guide_1-0.pdf
Please note you need to upgrade your VCS as well to at least 7.1.
I hope that helps.
Rafal
1 REPLY
Hello Steven
I hope that helps.
Rafal
289
