Static Routes
I noticed in the CLI interface you can add routes. Has anyone found any documentation on how this is done? Is this only applicable if you are using VCS with dual NIC?
  • TelePresence
1 REPLY
Static Routes
Hi Justin!
Yes, sure works fine. Dual Nic option is not needed.
And sure, its well documented, a good start is always the admin guide:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/admin_guide/Cisco_VCS_Administrator_Guide_X7-0.pdf
See, Page 65, 401, 455.
Description of the commands:
IP Route [1..50] Address: < 0="">
Specifies an IP address used in conjunction with the Prefix Length to determine the network to which this route applies.
Example: xConfiguration IP Route 1 Address: "128.168.0.0"
IP Route [1..50] Gateway: < 0="">
Specifies the IP address of the Gateway for this route.
Example: xConfiguration IP Route 1 Gateway: "192.168.0.0"
IP Route [1..50] Interface:
Specifies the LAN interface to use for this route. Auto: The VCS will select the most appropriate interface to use.
Default: Auto
Example: xConfiguration IP Route 1 Interface: Auto
IP Route [1..50] PrefixLength: <0..128>
Specifies the number of bits of the IP address which must match when determining the network to which this route applies.
Default: 32
Example: xConfiguration IP Route 1 PrefixLength: 16
RouteAdd
Adds and configures a new IP route (also known as a static route). Address(r): < 1="">
Specifies an IP address used in conjunction with the prefix length to determine the network to which this route applies. Default: 32
PrefixLength(r): <1..128>
Gateway(r): < 1="">
Specifies the IP address of the gateway for this route.
Interface:
Specifies the LAN interface to use for this route. Auto: the VCS will select the most appropriate interface to use. Default: Auto
Example: xCommand RouteAdd Address: "10.13.8.0" PrefixLength: 32 Gateway: "192.44.0.1"
RouteDelete
Deletes a route. RouteId(r): <1..50>
The index of the route to be deleted.
Example: xCommand RouteDelete RouteId: 1
712
