09-06-2013 07:49 AM - edited 03-18-2019 01:45 AM
I have an MXP in a remote office that is NAT'd and registered SIP/H.323 with our VCS-E. (running latest software). We have a standard VCS-E/VCS-C configuration at the home office. If a Jabber user (or any registered endpoint) at the home office tries to call the MXP (or vice versa) I get a half connection with audio working but video not working.
Here is the strange thing...
I have our VCS-E set with a default fallback alias which is our 8510 MCU autoattendant page. If I reconfigure the MXP so that it's no longer using our Gatekeeper (in direct mode) and I have them direct dial our VCS-E, they get the MCU autoattendant page and can join an MCU room without any problem at all.
thoughts on troubleshooting? Any help in advance is appreciated.
09-06-2013 09:20 AM
There appears to be media flow/connection issues. Can you please describe your Expressway configuration? Behind firewall? NATed? Etc...
Zac Colton
09-06-2013 09:35 AM
It's a standard VCS-E/VCS-C configuration. No clustering. The VCS-E is in a DMZ. What I'm confused about is why there would be flow issues when it's registered but none when it's not (in direct mode).
What other information would you like?
09-06-2013 09:37 AM
Does the VCS Expressway have the Dual NIC option? Are you running both interfaces? What kind of external firewall is it? Is it running and ALG or inspection for SIP of H323?
- Zac Colton
09-06-2013 09:57 AM
One NIC. (no dual interface)
The Firewall (On our end) is a CISCO 5540
on the far end I really don't know what kind of router. It was provided by the ISP (home router). We've not had any other problems with endpoints dialing in. So it seems to point to the router at the far end. Should I possibly set it for SIP to dial us (instead of H.323) and turn on STUN/TURN?
09-06-2013 10:24 AM
If the VCS Expressway is in a DMZ and is being NATed by an external firewall, you will need the Dual NIC Option on the Expressway so that you can configure the NAT address on the Expressway. For a detailed explanation of the design options, please take a look here:
Please take a look at Appendix 4 starting on page 56.
- Zac Colton
09-06-2013 10:26 AM
My mistake..the Expressway is not NAT'd, the problem endpoint is.
09-06-2013 10:32 AM
If the VCS Expressway is not NATed (it has a publoic IP address assigned to it and resides outside the external firewall), I would suggest running a diagnostic log and tcpdump on the Expressway and capture a failed call from start to finish. Within the diagnostic log and packet capture, you can review the media negotiation and the media streams that are being sent and received.
- Zac Colton
