SX-20 no audio in and out
I don't have audio at all (in and out).. there is any configuration for that.
It's problem with the codec because with other codec it works fine
Everyone's tags (1)
1 REPLY
When you say the other codec works fine have you tried it in place of the original with the same display, mic, cables etc?
If yes then I would SSH to the good config, use xconfig to display the config info then paste this into a text editor.
Swap in the dodgy codec, ssh to it and then paste in the xconfig data.
The codecs should have the same config and same peripherals so if ot still does not work it could be a hardware fault.
Hope this helps.
275
